marvel mystery oil
recently i was hearing alot about mystery oil so i was at the hard ware store and got a bottle a 32 oz its pretty big all it says in the back is to put it in gas tank of a car wat else can do with it for the nitro cars i no a few uses but can u tell me all the ones u use it for and also i have a motor scooter and i was wondering wether i could put a little of it in the tank
ooh yea it also says it can cause cancer:weird: so u should not come in contact with it:( well thanks :p |
You can use it for After-Run oil, and also for oiling your air filter. You probably can add it to your nitro fuel in small amounts, but I'm not sure if anyone has. As with all petroleum based substances there is a possiblity of cancer if your exposed to it for long periods of time. So don't use it for body oil. :D
thanks
thanks that was pretty funny
Marvel works great as a bearing and bushing oil, as after-run oil and for just about any general purpose oil application.
I wouldn't add it to your fuel, although if you do let us know what happens. . . your fuel already has oil in it. Marvel is good stuff, maynard! And since it's colored RED, it just might have some UV blocking properties. . . (red doesnt' let blue through) . . . . (ONLY KIDDING, don't slather yourself with the stuff and lay out naked. . .ick!) :cool: |
Originally posted by Boomer Marvel works great as a bearing and bushing oil, as after-run oil and for just about any general purpose oil application. I wouldn't add it to your fuel, although if you do let us know what happens. . . your fuel already has oil in it. Marvel is good stuff, maynard! And since it's colored RED, it just might have some UV blocking properties. . . (red doesnt' let blue through) . . . . (ONLY KIDDING, don't slather yourself with the stuff and lay out naked. . .ick!) :cool: I did it, It didnt hurt anything.. at the same time, i doubt it helped anything either. :p Boomer - Why not? I mean... all the girls love a guy covered in after-run oil. :p |
1 Attachment(s)
I have some of the marvel stuff (attached pic)
and it seems to work just fine...cause i cant see the piston through the case yet(good thing) Marvel mystery oil has tons ofuses maybe one of then is a tanning oil...so give it a shot...lol |
i love the smell of mystery oil in the morning!
Originally posted by TSR6 Boomer - Why not? I mean... all the girls love a guy covered in after-run oil. :p |
The Mystery of Marvel Oil
Guys;
In my Early days of Nitro, I tried putting some MM oil in with the Fuel. Added Oil, better lubrication. This made my Motor run MUCH hotter, drain the Tank, put fresh fuel, everything back to normal. You can use it for Filter Oil, but I find the Associated Oil lasts much longer and is Stickier to help trap the dust particles. If the Foam gets too dry, fine dust particles can actually migrate through the foam and get inside your engine. (This is BAD) As for a Suntan lotion, STP stays on better!:lol: |
girls in Indiana
Originally posted by Boomer Oooh yeah, but only those girls in Indiana. . . . :lol: |
Re: girls in Indiana
Originally posted by popsracer Could you send a few over to my House?!?! :D |
