Old 04-26-2003, 10:42 AM   #1
Send a message via AIM to tdragon
Default stalling
hey im new to nitro rc. the prob im having is my car stalls after i let go of full throttle. i took the time to break it in and now it does this. i have the hpi rs4 rtr3 with the 15fe engine and im running 20% ne help would be apprechated
tdragon is offline   Reply With Quote
Old 04-26-2003, 10:29 PM   #2
Default Your carb settings need to be.....
adjusted. Tell us how many turns you have on the high speed needle. If I'm not mistaken the HPI has only one needle which is the high speed needle. It is better to run rich than lean especially on new motors. Make sure that before you do any adjustments to the carb, the motor has some heat to it already. I mean don't adjust with a cold engine. Warm it up for a couple of minutes then do the adjustments. Start rich, run a couple of rounds then checking for acceleration(if it is bogging), bring the car back in and check the head temp. Lean out the carb 1/8 turn at a time on the HPI carb that would be a click at a time. Repeat this procedure until you are satisfied with the acceleration and make sure that the temperature is not too high. My friend has the same car as yours and I gave him an OS carb from one of my old motors and the thing was flying. I just recently modded the same motor for him with some polishing and mild porting. Amazing results, it really made a difference.
XtremeMDX is offline   Reply With Quote
Old 04-27-2003, 06:40 AM   #3
Default thankx
thanks for your reply ill try what u said and post back if it worked
Stalling Engine buggyrac3r Electric Off-Road 3 09-24-2006 04:12 PM
Help Plz: RS4 Evo stalling somegeek Nitro On-Road 0 05-31-2006 07:39 PM
Stalling Problem jonto100 Rookie Zone 5 06-01-2005 08:05 AM
Stalling O.S ScoopGrate Electric Off-Road 4 03-15-2004 01:56 AM
o.s stalling ScoopGrate Onroad Nitro Engine Zone 2 03-14-2004 04:50 PM
SEO by vBSEO 3.5.0
