Truing Question
So my tire truer is on the way, what should i true a new pair of foam tires to for 1/10 nitro tc. they will be jaco nitro shoes. ive been running pre trued so far but i dont know what they are trued too. thanks.
Originally Posted by NitroMaxx3.3
(Post 3444076)
(Post 3444076)
If you have a track with a lot of traction and low tire wear, you will want to run a smaller tire. A track with ok traction, you will want a taller tire so that you can get more side bite. Also, rounding the edges of the tire will make a difference in the way the tire will grip the track. A more rounded edge will be good for high bite tracks, and a more squar edge will be good for a loose, low grip track. All this will come to you in time...for now, just have fun and everything else will come with experiance. |
