engine problem >
engine problem
engine problem
Old 06-17-2007, 07:44 AM
tony montana's Avatar
Trader Rating: 76 (100%+)
Default engine problem
Im having a hard time getting my engine started. I raced last weekend and it started fine. Today I went to start it and it wont start. The plug is fine I even put a new one in it. The engine is a eb mods os 12 tz. It seems like the engine isnt getting any fuel. I have to turn it over on the starter box or about one minute just to see a little fuel going threw the lines. The clutch nut is tight also. Only thing i did different is I switched from tq fuels 30% to maxys 25%
tony montana is offline
Old 06-17-2007, 07:48 AM
Nitro$junkie's Avatar
check if you fuel filter is blocked
try pulling the fuel line off the carb nipple do the same on the pipe and blow with you mouth in to the line that goes in to the tank and see if fuel come's out the end were you just pulled off the carb nipple
Nitro$junkie is offline
Old 06-17-2007, 07:52 AM
usually if no fuel, or very little enters the engine it is due to a air leak in the tank. get some new clean fuel line, take all the fuel out of the tank and put the fuel line in top of the tank lid nipple
now block the fuel exit nipple and blow through the line, it should give resistance when you do this. If you get no resistance your tank has a leak. make sure that you take your finger of the fuel exit nipple before you stop blowing through the line or else you will get fuel coming up through the fuel line
another way to test the tank is put it under water, and do the same as above.
could also be a leak some where int he carb? it may have come loose.
TomB is offline
Old 06-17-2007, 08:44 AM
Team Kamikaze's Avatar
Try this..... open your HSN 1/2 a turn and start it, you'll be surprise that it will start right up.
Team Kamikaze is offline
Old 06-17-2007, 09:12 AM
NitroMaxx3.3's Avatar
Trader Rating: 19 (100%+)
o.s. engines are really tight. if it is new or recently broken in you will have trouble starting it at times usually about 8-11 tanks loosens it up nice.
NitroMaxx3.3 is offline
Old 06-17-2007, 09:25 AM
I did try opening the hsn a half turn. The engine problay has a little less than a half gallon threw it. When turning over on the starter box it doesnt sound like it is close to starting., sounds like when a plug is bad and trying to start it.
Old 06-17-2007, 04:14 PM
your carb is probably clogged from dried oil from last run,open hsn 2 turns and put it on starter box crank it and plug the pipe, you should see the fuel enter the motor,once started just rev it a few times and the close the needle back.hope this helps
GFIGUEROA is offline
Old 06-17-2007, 05:26 PM
mxwrench's Avatar
Charge your ignitor
mxwrench is offline
Old 06-17-2007, 05:47 PM
GHETTOTEACHER's Avatar
Check the tank, the hoses for cracks or leaks. If that dosesn't work, remove the engine and break it down. Check for garbage in the HSN or the banjoe fitting on the carb.
GHETTOTEACHER is offline
Old 06-17-2007, 06:35 PM
wallyedmonds's Avatar
wallyedmonds is offline
Old 06-17-2007, 06:50 PM
rcabj's Avatar
Default pipe block
just to share once i couldn.t start my engine...i was like spending half an hour to figure out , it was my pipe that had some blockage ,which blocks the whole cycle..
rcabj is offline
