Old 06-16-2007, 08:13 AM   #1
aussies1129's Avatar
Trader Rating: 74 (100%+)
Default G4S .12 running temp?
Hi i am in a remote area and know one has the G4S and I dont want to bother with the LHS as I got the car elsewhere and I have only been running .21/.28 buggies, I just wanted to know whats a good run temperature for the .12 and when tuning it will run for about 20-30 secs then die I am using a A3 plug and factory settings, maybe she is a little to rich? any suggestions would be appreciated
aussies1129 is offline   Reply With Quote
Old 06-16-2007, 12:06 PM   #2
razzor's Avatar
Tune it for response and perfomance and a guideline of 100/105 degc is OK.
The engines that come with it are SH .12 and they are very nice engines.
The std clutch springs are a bit soft and to me feel like they bog the engine down a bit ,this also agrevates engine temps.
Seeing you play around with offroad buggies try 1mm or 1.1mm clutch springs.
My sons Le Mans we use 1 ally shoe with 1.1mm clutch springs.
But it would depend on track or surface you run on.If you have good traction the harder springs would work well.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
OS Vspec running temp pracy Nitro Off-Road 9 05-27-2008 08:06 AM
what temp. should my rustler be running at? rustlermaniac10 Nitro Off-Road 3 08-06-2007 11:23 AM
What is best Running Temp on .21 OS V-Spec patrick21x Nitro Off-Road 2 06-13-2007 05:33 AM
SH .28 running temp? sausage_link Electric Off-Road 8 01-04-2006 08:49 PM
max P5 MF, Sirio Evo 2 WRC running temp raceblast Onroad Nitro Engine Zone 1 04-26-2005 12:57 PM
SEO by vBSEO 3.5.0
