Kyosho VoneR Thread
a couple more
last one
that's weird, tower hobbies sells their RR evo shaft driven
What do you guys think of the Kyosho One piece pipe?? http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXBMW2
Or a one piece pipe that's all black?? Any recommendations?
Beautiful car Ed, once I have some $$ to spare, I will be converting to the evo spec. I don't really need the whole conversion kit, just the gears, upper deck, and servo mount. Does anyone sell these 3 items all together?
nitropimp: nice ride bro...
Nitropimp,
Nice pic's . . . you've done well.
Rob Hochberg,
You could just change the .8M gears if you want but there's a bunch of other front end stuff that changed - I doubt you could just install the upper deck, and servo mount.
Remember the EVO front bulkheads are closer together, there's now a steering post, the one-way is narrower etc. etc.
In fact, with the EVO conversion kit, pretty much everything is new/different forward of the rear suspension and 2-speed assembly.
Rob Hochberg,
Thanks guys!!!
Location: Costa Del Sol, Marbella, Spain www.bradir.net
da show
is there an official site for the shizuoka hobby show?
Originally posted by Nitropimp
B4- You have to get Mugen:
Hub Carrier
Pivot Balls
Hub screws
Axle
Hex hubs
Mugen Dogbones
but well worth it. Camber adjustments are way better
Hub Carrier
Pivot Balls
Hub screws
Axle
Hex hubs
Mugen Dogbones
I did the conversion and the rear is to wide, got the pivot balls screwed all the way end and still it's to wide.
was able to use the kyosho rear swing shafts and wheel adapters, could that be the problem?
Fuel consumption
FINCHY:
How many minutes do you get on one tank with your Rody RB?
I'm having a hell of a time trying to tune it to go more than seven minutes. Is that even possible with the Rody?
Appreciate your response
Re: Fuel consumption
Originally posted by JPRacing
FINCHY:
FINCHY:
do you have to run different off set rims?
Re: Re: Fuel consumption
Originally posted by drfritz
thats about right for a tank of fuel, whats temp are you running at?
