Kyosho VoneR Thread
#781
Originally posted by Manticore
well, I think I shouldnt have lunch anymore cuz you guys are picking on me while I had my lunch !!
I thought you ate your lunch in front of your computer
#782
#783
OK test run of my one way today at the track.
First impression is steering and plenty of it. I actually was suffering from oversteer. I am running black front and silver rear. I think I need to go stiffer on the rear and front as the extra corner speed was too much for the softer spings. I was running 85% steering which seemed to be too much, so I went to 70% and it was calmer. Any setup advice for running a one-way? Reduce steering throw? Stiffer fronts? On power acceleration and steering was fantastic
#784
Oh yeah I forgot. I noticed that the filter in my tank has started to disintegrate. Anybody else noticed this?
#785
Regional Moderator
#786
Any more opinions on the one way setup. I bent a rear hingpin as well Better stop crashing And also the outer ball race of one of my bearing disintegrated. Anyone had some bearing failures??
#787
[QUOTE]Originally posted by AMGRacer
Any more opinions on the one way setup. I bent a rear hingpin as well Better stop crashing And also the outer ball race of one of my bearing disintegrated. Anyone had some bearing failures?? [/QUOTE
use higher WT shock oil and this will slow down the chassis movement. excessive chassis roll will also make your car oversteer. also use heavier spring will help.
#788
I also think less or no front sway bar in the rear
#789
[QUOTE]Originally posted by Manticore
finally at picture of moon - http://www.geocities.com/teamhardkor...manticore.html
#790
#791
#793
Im not worried about the rust - 22years racing????????
How old does that make you Moon? You should be world champ by now
You didnt see my title on top of my avatar?? I am world champ already mate !!
#795
hey check your mail grand dad - ....oooppss sorry Moon.
Will get back to you !!
Cheers !
