Kyosho VoneR Thread
#6016
Originally posted by kevink2
Wow a 3mm difference in tire splits! Doesn't that kill the belts?
Regarding springs, I was using the golds in the front at KZ (big track) and blacks at Revelation. Golds all around bounced quite bit, even with heavy shock oil, so I went back to blacks with 60 wt in front and 40 in rear. Car was much easier to drive with blacks. I'll compare springs rates with my MTX.
Strange that it was bouncing I have never had that problem. Our track is not really that smooth either.
#6017
Re: MTX-3 Rear Setup
Originally posted by rskoncepts
Sorry to change the subject...
Has anyone had time using the MTX-3 rear setup and come up with suspension settings? Compared to my original GRP foam car parts, I had a little more slide in the rear but it was stable and controllable. Tire wear was good in the rear.
#6018
I am using like 4 or 5 shims well however much they supplied me
#6019
Are they going to keep this design for a while?
Who has a great supply of parts?
#6020
ne one plz help???? i have used up all the shims provided to space my car and the clutch bell is stillhard
#6021
#6022
I've got it near full stiff as it is. I guess it's the on power turns where it gets a little more dicey, especially after driving my friend's MTX-3 (ooops did I say that?) and then going directly back to the 27t. Does the 25t supposedly yield more top speed Manticore?
You should stay with same front/rear drive ratio all the time.
#6023
More Top Speed
Vince
P.S. I think I already asked you, but do up one of the Proto Stratus 2.1 bodies for me! Just in case I forgot!
#6024
Yep you're on the list Vince.
Yeah that gear conversion you got is insane. More rollout would help with the current configuration at KZ. As it was I just barely had enough with new tires. I'm a little worried about the bottom end gearing with that conversion though, so keep me posted on what happens with your testing.
I'll have to try running the smaller fronts then. So by running more even fronts maybe I was straining the belts, because I broke a few a couple weeks ago. Now I've got even more stuff to try. I've also got my eye on a smaller delrin spur gear (43) that I've seen with a certain someone we know in the pits.
#6025
Hey Kev, so are we gonna come up to the north to run our small tracks or do I have to come down there to bug you on your cell phone when your turn marshaling
Oh yea I wish I could race on a track with gearing problems
#6026
#6027
Hmmm.....
#6028
#6029
What exactly are you referring to?
Well if that is the question you are asking, then I have not seen any indication that the V One RR is going away. As far as parts, Tower Hobbies has most of the parts. But if you want a good selection of factory parts and Hop ups I would suggest you go to RC Model. THey have a great selection of hard to find V One R/RR parts and all my orders were shipped to me within 7 days.
Tower Hobbies
RC Model in Hong Kong
Hopefully this is what you were asking. If not then too bad!
#6030
Re: Hmmm.....
Originally posted by Bounty Hunter
Well you are right the conversion does add a ton more to the rollout, but I have severly geared down to compensate for it. With the 24T conversion I am running a 15/19 pinon with a 45/49 spur. I think as far as gearing goes this may be the ticket. Even Tony sees that I keep up with him on the straightaway. As far as cooking motors, well I myself am still running at 235 (race temp). Getting plenty of rollout at Revelation. Now I just have to work out the handling issues and I am set.
