Kyosho VoneR Thread
#5806
Would there be any pipes out there that u would recommend to me besides the nova pipe i was thinking about and THX for the lightening speed responses. Also i have a friend that was thinking of doing a v1s conversion to a r would that be more than a brand new r at the end?
#5807
Talking about pipes... What do you guys recommend for an torquey inline type pipe?
Most inline pipes I know are high revving ones. Thanks.
#5808
Generally you cannot convert the S to a R without substantial amounts of parts. It will almost certainly be cheaper to just get an R.
#5809
BLEH!! thats it imma go get me a r tomarrow or friday someday it's driving me crazy!!!!!first i have to finish finals ewwww
#5810
There is a good post on the "Richey" thread about different pipe and engine combo's
#5811
for those who have done the mugen mod, how do you personaly feel about, how your car handles with it.
Me I am still waiting for parts to try it
#5812
#5813
Originally posted by AMGRacer
If you run rubber tires you are better off without it. If you run foam tires the rear of your car rolls less and has more grip in high speed corners while maintaining low speed grip. Basically it makes the car easier to drive fast.
NICE
#5814
Your trying to tell me someone still uses rubber tires A
NICE
NICE
But if you get a spare set of kyosho rear arms you can convert back and forth in around 2 minutes.
#5815
I ocassionally run at a track which is effectively a concrete walking path around 5 feet wide which they race on. Crazy? Yes. Long story short foams dont work there as the concrete dust makes it slippery.
#5816
Originally posted by Manticore
you dont need to, just reduce the shims !
#5817
Originally posted by Robo
Any other tips? Keep them coming.
Thanks Jonathan for those driving tips.
HaaaHaa.
No problem....that's what bench racing (lap top racing in this case)is all about....BS'ing.
#5818
Even lowest shims is around the top hole of the kyosho hub. I find the best is top inner and bottom outer for concrete walking path tracks This minimises the camber change. Mayby I am too fussy
#5819
Would this mod behave similarily to having the gold rear sway bar? I mean... I understand that they reduce roll by different means...but I was just wondering...if you guys have tried it ( the gold rear sways )??
#5820
Lowering the rear camber links changes roll centre, what track conditions call for altering roll centre?
