Kyosho VoneR Thread
#4246
Originally posted by calimassive
i should be getting my V1rr in the mail any day now. It's my first nitro touring sedan. Anyhow, i think i have my mind set on an RB-X12 engine, but im not sure what pipe and header to get. I heard the Paris ring pipe is good. Any other suggestions?
#4247
Spur gear
hai...
do fantom spur/pinion gear can be use in v1rr? How to calculate gear ratio..And what best for short/technical track and long/big track?
thanks
thanks
#4248
yes, fantom gearing works on V1. Take spur/pinion to get gear ratio. Multiply this times internal gear ratio to get FDR.
For tight track, stock 16/20 pinions on 49 1st gear spur works good for me.
For big track, try 18/22 and look for smallest 2nd gear spur. I have 45, I know they use 44 on reflex, but not sure if kyosho has a 44. The guys overseas apparently can get a 43 from aftermarket.
Cyrul runs 23/44 when at the cincinnatti track on his reflex, but don't know when they are going to make that pinion.
#4249
oh yeah your tire size will affect your gearing as well so you may desire to calculate rollout. I personally focus more on calculating overdrive ratios than gearing - especially with the centax on there you can adjust so much with the clutch for take-off and speed I just want the handling to be consistent by experimenting with tire size and overdrive ratios. Just my .02 - the other more experienced guys here may have a different take.
#4250
what kfactory hop up should i get first, price shouldnt be an object
#4251
hey jack, nice site. Nice pics of the V1rr. What kawahara hop ups do you have on you're V1rr?
#4252
plenty ..
let see.
soild axle
radio tray support.
Mid pulley support
left brace
wheel hub adapter...
and some others that i cant rem
#4253
#4254
I think Manticore has an opinion about them...
#4255
my lhs doesnt stock kawahara,none of the hobby shops in my province dont stock kawahara, lol
#4256
Originally posted by kevink2
First nitro sedan? Get the RD Logics in-line one-piece. Around $40 bucks for the ROAR legal, nice polished aluminum. The non-ROAR model is even cheaper, I believe. Performs well, can't beat it for the price (I think HAG will back me up on that one). You can try to find the one that will yield you the best performance, etc., blah blah blah, but realistically, if this is your first nitro sedan, you're going to bash it a few times before you get it running well (especially if you're a novice driver), and the pipe is always the first thing to get damaged. Nothing like smashing in your brand new shiny RB pipe on the first run (I should know!). All it takes also is one hacker t-boning you on the right side. The RD Logics pipe also comes with all the springs, couplers, etc. you'll need, and they also throw in a shiny pipe hanger wire.
I also have a RB X12 and a turbo ring, both of these work well also but hear is the kicker
Turbo ring =$40
RBX12 = $45
RD Logics in line = 39.95 and comes with all the goodies
#4257
Originally posted by Sydewynder
kakaka is Manticore laughing at you.
kakaka = kekeke = hahaha = ahahaha = muhahaha
Comprende senor?
Comprende senor?
#4258
thanks kevin k2 for the pipe suggestion, appreciate it, btw, im scared about one thing. That the front one way is gonna make it hard for me to drive. I mean, i took the plunge and got the V1rr anyways, but still, any tips on driving the V1rr, mainly to avoid crashing and to keep it under control? I've never driven a nitro sedan before. LOL...
#4259
lol, why didnt u get the rubber tyre version then?
it doesnt come with a front one way or a rear solid axle..
#4260
