Old 06-12-2007, 07:46 PM   #1
Default Throttle Servo Recommendations
My servo died last weekend at the beginning of my main. So, I'm in need for a replacement.
Any recommendations?
Serpent 720
Steering servo - Futaba S9451
neltime64 is offline   Reply With Quote
Old 06-13-2007, 01:32 AM   #2
M7H's Avatar
My throttle and steering servo are the Robbe/Futaba S9402.. Yes, analog, not digital.
Why not digital..
Well, because a digital servo draws more current from your battery pack...
A digital servo will draw maximum current always, until it reaches it's desired position, while a analog servo will draw maximum current while traveling to it's position, but less current when it almost reaches it's desired position.
So escpecially for your throttle servo, while under breaking, a digital servo will draw a lot more current than an analog one....
M7H is offline   Reply With Quote
Old 06-13-2007, 01:45 AM   #3
gansei's Avatar
because much consumption electric power of digital servo
i also knew that throttle servo must be used analog servo in several years ago.
But recent receiver battery had big capacity.
so many RC users are using digital servo in throttle servo.
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 06-13-2007, 03:52 AM   #4
1fastdude's Avatar
Trader Rating: 15 (100%+)
JR servos................great service and dependability. Analog or digital.
Team Horizon-Team Spektrum-Tekno-Kyosho*B-FAST R/C Performance*TQ Racing Wire Products-TNT-FX.COM-Avid RC-Dynamite-*AKA*92Zero Design*
1fastdude is offline   Reply With Quote
Old 06-13-2007, 04:23 AM   #5
I run the KO servos for both throttle and steering. They are digital but with 1400maH battery pack, battery life is not an issue. I can run an hour main easily. The servo for steering is PDS-2368-ICS and PDS-2367-ICS for throttle. They are very dependable and tough. I haven't had any issue with the ones in use in my 1/8th. They have built in heat sinks to help remain consistant over a long main, which some other servos have problems when getting warm.
More info available at www.kopropo.com
Brian Berry is offline   Reply With Quote
Old 06-13-2007, 05:24 AM   #6
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
jr 9000t a bit of over kill but reliable smooth.
ammdrew is offline   Reply With Quote
Old 06-13-2007, 09:40 AM   #7
I have that servo and it works great, its small but will do the work of the the throttle. On steering Im using Futaba 9550.
Have fun and hope it helps
ALG is offline   Reply With Quote
Servo Recommendations Dorikin Radio and Electronics 0 02-07-2008 06:14 PM
Servo recommendations for 8ight spinall4 Electric Off-Road 17 12-23-2006 11:51 AM
Hyper 7 PCR Servo Recommendations? SUNA Electric Off-Road 8 03-12-2006 03:50 PM
3PK / HRS servo recommendations? billwilner Electric On-Road 17 12-26-2005 10:05 AM
Servo Help - Recommendations Please rctoyguy Electric On-Road 12 11-09-2004 11:22 PM
SEO by vBSEO 3.5.0
