Schumacher R12 Fusion
#511
And here is when you use aluminum paper front and rear diff ball bearing mounts or the other solutions to fix the slop issue.
#513
Here are my R12's One for race and the other for spareparts or test drive.
#514
Third issue (actually not an issue, but a disadvantage for this car): The R12 Clutch.
Pros: Nice for bashing, or running around.
Cons: Not competitive for touring races compare to the other cars around today. Not even modifying the shoes, springs, etc still was in disadvantage.
First Possible solution: A Centax Clutch. But it never happened.
Second Possible solution: A push type and adjustable clutch so it can be used with you're regular stock clutchbell with gears. The options are the Werks and the SPM Clutches. I first had the chance to verify with the Werks clutch, but I think it didn't work for some kind of a reason the clutchbell didn't fit with the Werks clutch. Although both clutches looks the same, but there internally diameters are different. (I might be wrong with this, but is up to you if you wanna try with the Werks Racing Clutch then, but I'll try to verify again if I can find a Werks clutch in the future.). In that case the SPM Racing Clutch was the one to choose.
Parth numbers:
SPM108A - it comes with black carbon shoes. Good grip with mild slip and wear.
SPM108R - it comes with red rulon shoes. More grip with non slip, but with fast wear.
You don't want to use the teflon white shoes otherwise you'll wouldn't being upgrading.
Some hints and advice: Was kind difficult to search and buy this product on the internet, because most of them you'll find them on Italy web sites. (In my case though because I live in the US territory) The official web site for this clutch is http://www.spmracingparts.com/ and I think you can't buy nothing from them. Once you have you're SPM Clutch in your hands, please be patience. This might or might not work in your first attempt so take you're time. This is going to be more like a trial an error until done. But once you're done, you're gonna gain a great reward from this upgrade.
I'll try to explain the things that needs to do bit by bit, to fit this clutch on you're Fusion R12. But for some of you who have more experience and have better ideas, please put them on this thread so we can all help each other.
Z
Parth numbers:
Z
#515
Some pictures of the clutch
#516
Ok, here is the whole set of clutch system in separate pieces.
Another pic from a top view
#517
Ok, let's roll
First step is to shim or to get some spacers to put them so the MAIN Belt pass trough the engine and the flywheel without rubbing. They measured about 3mm with 1/8 wide, this is the basic from here on, so the rest it will depends on your engine. Let's hope you can make it without a problem. Next is the engine cone, so here too it depends on your engine. I used the rossi one though.
#518
Lets start to install.
Here you install the 3mm spacers on your cranckshaft.
Later the engine cone.
Next the flywheel.
Later after that, put and screw the clutch nut. I suggest you do some trial an error with this before continuing the next steps. Because for some unexplained reason, If put more shims or spacers, the clutch nut would not grip the flywheel, if I put less shims, the flywheel gets loose completely. After this try to install the engine an check for the passage of the MAIN BELT.
Your engine should look something like this. It looks like it is rubbing but is not. I'll post some more pictures later.
Next the flywheel.
#519
Alright, once you finished your previews step. Put some tread lock on your crank shaft thread so the clutch nut could be very tight.
Then put the shoes.
Then the pressure plate.
The hard spring(silver).
The adjuster Nut.
You can start to adjust at least 1 thread expose, I'll explain later what happens.
Your bearing, you can use a 5x9x3.
Then your engine end cap.
The clutch bell.
The bearing flanged.
The engine screw with the washers. Put some a bit of thread lock just in case. I had some bad experience with this.
Alright this should be it. Clutch complete.
Then put the shoes.
The adjuster Nut.
The clutch bell.
#520
Ohh! one last thing. I had to put some washers on the engine mount, because the flywheel rubbed the floor when I run my car and chew the outer of the flywheel and a couple of times the engine stopped. But didn't happened that much just one or two. The R12 stock flywheel measures 34mm, the SPM flywheel measures 37mm. So it will rubbed the floor.
#521
Some more information installation of the clutch if you like.
http://www.werksracing.com/powerinstructions.html
http://forums.thetoyz.com/index.php?showtopic=3117
#522
Z - it's really fun to read your howto's, but in all honesty, I think you're alone with the car... the R12 has been dead for years and we should let it rest in peace. Just makes me wonder if you really REALLY have nothing better to do with your time than to write howto's about a car that nobody runs any more
#523
#524
Well, lets continue. Here's another pic how the Main Belt passes under the spacers from the engine.
#525
Are we done and finished? uum Nope not yet! You wonder on the previews posts that I made and says why you can't expose more than 1 thread on the clutch nut adjuster. Well because after some test drive this 3 this happens! Sorry, It was unexpected to me too. This 3 parts got damage by the great force of the SPM clutch(Centax wannabe)
1. The diff screw got torn apart in two pieces.
2. The 1st Speed One Way Hub just unglued it self from the hub case.
3. The Layshaft pulley internal pin got broke in two pieces.
And you ask your self. Will I keep going to deal with more problems that I had with this extinct dinosaur piece of crap? I'll just go away and use my newer model and all my problems are gone.
You know, you're right! Well then go ahead and do it. Otherwise just stay a little bit because there always a solution for everything.
That's why Schumacher suspended this car. The thing is... that I don't understand is why revive the M1 electric car if is the same old Mission from almost more than 10 years. And is the same chassis as the R12, only with nitro engine. So it still lives, only with a different name. And heard they have similar problems.
