PERFECT BODY CUT OUT..
Does anyone have an idea on how to make the perfect cut out for the top of your body on 1/8th scale, a template trick or anything for the mounting holes, fuel cap, roll bar, and filter, all help is appreciated thanks...
You can use a template from an old body (as long as it the same body), by simply cutting the old bodies sides off where the top meets the side (the lip).
I've gone around this a few different times, and I still find the best way is to take the motor out of the car and mount the body while it's clear. With the motor out, you can set the body on top of the body posts and move from side to side to get the correct side clearance (body to tires) and then the amount of overhang of the body to the front bumper (can play into handling).
Once you've cut the post holes for mounting the body, reinstall the motor and roll bar, and start small then slowly enlarge the holes for the motor/carb and roll bar to fit through the body.
I agree a template from an old body does the trick. Now if you attend BIG! races like winternats etc. you will find that the some of the TOP drivers will either give or simply throw away the slightly tranished bodies. Nothing wrong with taking one of those and make a template! Sweet
Cut outs
I have a lot of different body styles ranging from frizbee, central, R11, Kawahara, shadow. can i use this technique on all of these as well?.
If I don't have a template from the same design body (Lola) and I need to lay out the cut-outs. Before I paint and the body is clear I set the car on a flat surface with the tires, body mounts and motor (minus the heat sink and filter) on and the roll bar off. I then line up the body where the tires work best and mark them, then mark the boy mounts, antenna, roll bar and fuel openings. For the motor I set the heat sink on top of the body lining it up with the motor and mark it and the filter and high end needle as well.
The only problem with using an old body for a template is that it has usually been hit or damaged...hence "old body." Some of the body holes may have shifted slightly.
There is an expensive way of doing it: Use a new clear body as a template. That way you can mount it perfectly and even write comments on the body for readjusting the holes for future handling effects. Cut the sides off and only use it for cutting new bodies out. When you have a lot of bodies, this gets real expensive though.
Lexan thickness
Yo crunchone, i was thinking the same thing, soundslike a good idea, do you know what thickness lexan he used?.
lexan thickness
Sorry bro, Krunchone..
I use an old can of Pactra spray paint with sandpaper wrapped around it for the wheel wells and the hole for the motors heatsink and the INS box...
That can seems to be the perfect size and the holes are perfectly round and smooth
Cut outs
These sounds like some good ideas.
