Mugen MTX-2
#1441
Tyres
ok then anyone got some good rubber tyre info for the uk??
#1442
I also can testify! I have done so many cart wheels with my mugen its not even funny. Last weekend was the worst it must have tumbled 20 times!! And as a cople of fellow racers ran out on the track to grab it from being hit becasue they just knew it was gonna be all broken up. The last tumble it took it landed right side up and a few revs of the gas and i drove the car perfectly fine to the pit area to check it out. They were amazed!! Needless to say I was too
#1443
#1444
A stupid ?
the short springs are for the front and long are for the rear right???
#1445
Re: A stupid ?
#1446
Re: Re: A stupid ?
Originally posted by Manticore
Yes.....
Yes.....
#1447
going to fire it up tomorrow if weather permits me too !!
hey guys i got this trinity nimh 5 cell battery pack for my mtx-2 , but i am not sure how long to charge it . it came with out instructions, it looked repackaged. but i am using a wall charger for nimh 5 cell battery packs (ofna). it has a light that comes on when you plug it in. does it go off when it is done or what ? thanks for the info.....
#1448
Re: going to fire it up tomorrow if weather permits me too !!
#1449
#1450
Have any of you switched form 20% Nitro to 30%?? Any pointers I should know? I been told treat the engine as if ti was new and re break it in. Any commenst would help.
#1451
engines
ok i have a rossi rs12 and have trouble with the front bearing leaking what do you suggest Makes etc
Tried Rossis high spec one but still the same
#1452
Mr MTX
Usually whenever you switch fuels, it's a good idea to run a couple tanks through at a "break in" pace to allow the residue from the old fuel to be replaced with that of the new fuel.
#1453
Originally posted by psycho
Mr MTX
Mr MTX
different % of nitro fuel has the same component. i.e. same lube, same cleansing agent, same nitro, same metho......... but different %.
#1454
Re: engines
#1455
Re: Re: engines
i have the same problem with my RS about fuel leaking when it is NEW. after i reseat the bearings with the novarossi bearing alignment tool, the leaking stops.
