Mugen MTX-2
#856
Ah10 where do you get the Hyspin Lube for the negative diff. I am currently have diff oil in it and I read your post that the diff actually will wear itself out.
#857
Re: Re: Servo Question
Originally posted by Ah10
I am using JR digital servo DZ8450, rated 0.08sec/60 degree, torque is 98oz/in. I think the holding power is over 133oz.
#858
Thanks for the info ah10.
Manbik: are these high speed digital servos more easily broken than normal ones or was it big wreck which broke yours? Truth please!
#860
The one I have is Racer's Choice Hyspin Lube #7016.
The one from Tower Hobby is #7020 from the description it said "Racer's Choice Pro Diff Lube 1/2 oz, This is a 1/2 oz. bottle of 100% synthetic lube. It is ideal for differentials and can also be used for king pins, steering linkages, ball-ends, shock shafts, hinge pins, or disks.
I am assuming it is similar stuff and should work the same!
If I could find it some where that you can get then I will update you!
#861
#862
Thanks Ah10!
#864
Thanks Ah10!
Thanks Ah10!
#865
Yeah H.K. j/k I'll let you know if I come across some.
#869
Or combine the 1.1mm springs and the white shoes and build up even more revs. That's what I was doing.
#870
Manbik
HEY Manbik
This is Rich... I bought your car.... LOL!!!
I went thru and rebuilt it, so I could get familiar how everything went together. I rebuilt then engine (well kinda), and I wasn't careful with the clutch shoes, I cracked one of them....
So for now I have the black clutch shoes on. The engine looks pretty good, but compression is lite, so I should replace the piston/sleeve... BUT I can do that later. I started it today and it fired right up!
I did add a boost bottle to it.
Right now I have to chase down a steering servo glitch.... could be wiring, or low batts...
A bud and I are going to set the chassis, after that I'm gona try it out at the college lot where RAMS races.
LOL!!
Rich
How is 1/8th treatin ya??
LOL!!
Rich
