Mugen MTX-2
#181
Different types of pulley(s)
An 18T pulley. A 19T pulley. What do the different types of pulley(s) do for perfermance? These are for the side, right? Thanks.
#182
Steve,
Did you get Kawahara roll bars in? Your site says they are out of stock. I heard they are backorder from Kawahara.
#183
Re: Different types of pulley(s)
18T is on the right side of the mid shaft pulling the the long belt(front diff)
Hope it helps
#184
Guys,
has anybody ever tried to fit a clutch type 2-speed on the MTX2?
I don't know about you, but with my engine, the little pin in the 2nd gear housing gets bend and tortured big time and I replaced the housing recently because the aluminum around the pin started breaking.
#185
Originally posted by stefan
Guys,
Guys,
Shifting too late will kill your housing pin, too much power for it to handle!
I remember someone has posted a replacment parts that has 2 pin in the housing! but forgot where! it's a custom modified part!
#186
#187
AH10, thanks for the tip.
I'm running a Ritchey RTU engine and it's way more powerfull than the original MT12
#188
Kawahara suppose to have a 2 shoe 2 speed. Maybe Speedtech will carry it.
#189
#190
#191
Originally posted by Manticore
W Fok, I prefer the stock finger type 2speed clutch over the clutch type. The stock 2speed clutch works great already.
AH10 Such langauge. LOL
#192
The finger type works for me too but stefan is having problems with his RTU.
#193
In fact the 2nd speed engage smooth if you assemble the 2speed correctly. The finger should not "HIT" the pin when gear shift. Better check the direction the way the finger goes.
#194
No problem man, if you are running Ritchey RTU engine then you should make the son of a bitch shifts earlier to get everything out of the Ritchey! Wouldnt you agree?
The thing with the Ritchey engines is the torque. With a high engagement point, I was literally spinning the tires when it shifted into 2nd. In addition to readjusting my shift point, I had to go up a tooth on my pinions to help keep the tires on the pavement.
#195
Almost forgot.... HAPPY B-DAY NR!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
