Mugen MTX-2
#1876
Re: Kawahara rear arms
Originally posted by stefan
Does anybody know where to get those "unbreakable" rear arms that come with the narrow rear end conversion?
I broke one
I broke one
#1877
That's what I was hoping, but who carries them?
Thx
Thx
#1878
the parts you're looking for:
http://64.70.208.72/speedtechrc/112.html
but they are out of stock, you might wana try castle hobbies aka RC Imports...
www.castlehobbies.com
(408)377-3771
Rich
BTW - you still doing the anodizing?
(408)377-3771
Rich
Thx
Thx
#1879
Does anyone know if there is a solid front axle for the MTX2. A group of us were in Cincy for the weekend. If you ever get the change to go to that track you need to go. IT IS AWESOME!!!
#1880
Originally posted by larry murphy
If you are running your fuel line between the carburetor and the cooling head, try turning the inlet nipple so it points to the right side of the car, then run your fuel tubing around the carburetor. This way the fuel is not heated by the cooling fins. It works, give it a try.
I tried this and I did not overheat the fuel Firday or yesterday. Friday it was warm and I ran only 1 tank. Yesterday was cool, 58, but no vaporlock and I ran 2 tanks nonstop.
#1881
RC Nitro, Your welcome, it's almost to easy. Sometimes all it takes is a simple fix. WE always try to complicate things.
#1882
Hard Jokur,
that's the whole kit, I'm only looking for the arms.
Larry, Fiorino makes one. I think GS Silicones are the importer.
Are you going to be back at the bowl next week?
#1883
Stefan, try giving Castle Hobbies a call. If they do not have them you might want to try RC Imports directly as they are not the same company.
Regarding the new Kawahara clutch this thing looks to be super trick as it is a minaturized centax clutch with low height engine mount. It's significantly lighter and smaller than the stock mugen one and even the Kawahara small diameter fly wheel. Supposedly it is so small that it allows the engine to be mounted almost flat on the chassi for a super low CG! Check out the picture.
#1884
John
#1885
Stefan, Thanks, I will try to find it today. I don't think I will be there this weekend. Need a little break.
TKT,
Thanks for pointing out the size on the new centax clutch. Your right , IT IS TRICK. Need to take a closer look now.
TKT,
#1886
Larry,
come on, breaks are for old people!!!
If you can't find that solid axle, you could still JB weld you original front diff....
Why do you need it anyways? What is a solid front supposd to do? Take steering out or give you more?
Later,
Stefan
Later,
Stefan
#1887
Stefan,
From what I understand you lose a little steering, but you get full time braking back. You know, so you can drive harder into the corners.
#1888
and you will push like a sled
#1890
front gear diff in pro spec
Where do i get a front gear diff for the pro spec?
