Mugen MTX-2
#1771
Looks like a copy of the one from Kawahara's page.
#1772
Originally posted by Ah10
This is so cool! oh does anyone know how to calculate actual speed of the car with tires diameter, engine speed and gearing?
#1773
Looks like the MTX-2 is STILL kickin' a$$ all over the world.
www.mugenseiki.com/2002nsw-on.htm
www.mugenseiki.com/2002sanpaulo.htm
www.mugenseiki.com/2002mugen-6ke.htm
I'm keepin' mine!!
I'm keepin' mine!!
#1774
I'm keepin' mine!!
I'm keepin' mine!!
#1775
Good setup for one-way and rubber tires
Hi guys,
Can anybody suggest a good setup for my MTX-2 with one-way and rubber tires?
I also use touring body.
#1776
Neg Diff
ran car today and all was well qualified 16th in the UK nartionals on rubber
#1777
Mark: Congrats!
aftalavera: I am at work so this is off the top of my head. I run the stock prospec setup and this works great. I am running a gear diff in the front now as the track is tight and a negitive diff in the rear.
ride height: 4mm F 6mm R
Caster 2mm shim
Camber 1.5 F 2.0 R
Toe: 0.0 F 2 in R
Droop, here I am not sure, 4mmF 8mm Rear
camber rise is 1.5 F 2.5 R
Shocks: 600 wt, laydown both front and rear, lt blue springs
sway bars: 0 deg F 2mm rear
Tires: Treadz 3B, 3A for cold. Dia 64 mm 26mm
Rollout 27.1 first, 37.0 2nd
Foams I like 37F and 42R Like AH10 I like a harder rear compound.
Caster 2mm shim
Camber 1.5 F 2.0 R
Toe: 0.0 F 2 in R
#1778
RC Nitro:
Do you use that setup on rubber tires and sedan body?
#1779
Mark:
Felicidades !!!
Felicidades !!!
#1780
Originally posted by aftalavera
RC Nitro:
RC Nitro:
#1781
RC NItro:
Thanks.
What about diff oils?
Good luck this weekend ...
Thanks.
#1782
RC NItro:
Thanks.
RC NItro:
Thanks.
Thanks!
#1783
what does this mean??
Mark:
Felicidades !!!
Felicidades !!!
#1784
translation
Mark
It is a spanish word, translation is below.
-- Translation Results by SDL International --
Happinesses
----------- Your Original Text ----------------
Felicidades
Happinesses
Felicidades
#1785
translation
That is the disadvantage to use the translation machines hehe.
Actually "FELICIDADES" means CONGRATULATIONS.
You deserve it Mark.
