Mugen MTX-2
#1741
Re: Foams
Originally posted by RC Nitro
I made the main yesterday only to have rain stop the show. Car was tight most of the day. Prospec with gear diff (10,000) and negitave diff in the rear. Running 42 shore all around. Front plowed bad Track was very tight and dusty. Switched to purple front (40 shore??) and tire tack. This helped some what. Purple springs helped more. Looking for a recomendations on some foams. All we have local is Treadz, 42's No 40's Thought about trying 37 & 35 front...... would this work?
Also what is the differance between the front and rear foams?? Both are 26mm
TIA
TIA
I am currently using 40sh front with 45sh rear tires and most of the ppl call me crazy but it works good for me! I have notice using such combo on my car's set up gives me much more steering responds expecially doing those tight hairpins, S-curve(hard left then hard right). Tire wear seems really good! a set of front 40sh last me at least 4 weekends of hard running!
#1742
Re: Re: Foams
Originally posted by Ah10
first of all, front 40sh is different from rear 40sh!
#1743
Originally posted by AMGRacer
I just love huge stingers.......................... When they write turbo on the pipe it just has gotta be fast.
#1744
Originally posted by dtm
Sure looks nice....when it is still new!!!!!!
#1746
Re: Re: Re: Foams
4 weekends!!! thats a lot!!!! How much fuel are you getting through??? I worked out that I can managed about 2 litres of fuel for fronts and 1 litre for rears...both 40sh. That equates to about 26 and 13 tanks of fuel...or 2 weekends for front and 1 weekend for rear!!!
#1747
Re: Re: Re: Re: Foams
Each weekend I run about 8 to 10 tanks, so about 750cc or so! also the track that I am running has very high traction too and it kind of save tires!
#1748
Manticore- Saw something new in that shop we both love!!! Man Lee..... he has the front butterfly VDS body mount plate like the RR for the MTX2 made by Kawa......first time I've seen this option!!!
#1749
Ah10: Thanks for the info!! I just ordered some more tires. 37 & 40 shore fronts and 42 shore rears. Like you I like a harder rear compound. I do not like a tight rear for my style of "driving"
Thanks again
Thanks again
#1750
#1751
#1752
Negative diff
i have mine built but it will only lock on acceleration not if onne wheel spins is this correct?? as i see it if the left wheel is still and the right wheel spins the diff will not lock only whenn the diff is rotating at high speed will the shoes lock
Whats your theories??
#1753
Originally posted by hurhur
is there such an option by Kawa? its not listed on their website and they do update their page constantly.
#1754
Originally posted by Manticore
Never want to go to that shop !
Don't like the place because we went in once and asked for the price of a KO 2001 servo...first time he said $450.....we did a usual round of MK and then went back to buy (well KY was buying)...he then came back with a price of $500...saying that he did not say $450 before hand!!!!! there was 4 of us, 4 pairs of ears....and we are all deaf!!???!!!!
#1755
Re: Negative diff
Its all about how quickly you can spin that plate the clutch shoes mount on! whether it be via the rotation of the entire unit or the rotation generated with the differential action.
PS. don't try the drill trick....chances are the gears cannot cope with that speed!!!!
