Mugen MTX-2
#1636
to ah10 , and the rest of the guys that gave me building support.
those pics were for you. thanks alot guys for the info...
#1637
Originally posted by RC Nitro
I prefer the lola body over the 4 door sedan's. 4 door car is not a race car to me. I run the BMW LMR on my super, and Porsche 962 on my vector. I have already ordered the Lola body and mounts for mine. Want to get rid of the stratus body. JMO on the bodies. Tekrsq , where do you run in Richmond? I run at Debbies in Va Beach
Anyway, I run at Hobby Corner on Hull St. I've been to Debbie's a few times a couple of years ago.
#1638
Originally posted by tekrsq
Nothing wrong with different opinions, it makes the world more interesting.
I have nothing against the lola and other "wedge bodies", just they don't belong on a touring car. I just feel if I wanted to race a wedge, I'd buy a MRX3. And I think the spectators would get bored watching 4 or 5 classes that all look the same. Variety is the spice of life, lol.
#1639
Re: to ah10 , and the rest of the guys that gave me building support.
You are very welcome! I mean it's sad to know you have to let go of your car!
#1640
re;
hopefully things will pan out soon, but as they say sometimes $h@t happens sometimes...i will be back though....
#1641
Re: re;
check on this forum from time to time! stay in touch!
#1642
any of u have any tricks to repair dented tuned pipes? i only know of the ice expansion technique.....anyone has tried this and have other better methods of doing so?
#1643
The ice trick works well for a dent near the stinger and depending on how bad the dent is you may have to repeat more than once to get it back to form. The only down side is that if you get hit more than a couple of times. the technique will expand your diameter of the pipe bigger than it original size.
#1644
During my 30 minute main I had a problem with my 2nd gear. It would not engage from time to time, the car would just slow down while engine was reving up. What happened and how can I fix it?
#1645
#1646
Diff Oil
Can someone enlighten me on the reasons to change the diff oil to heavy/lighter grease. The tracks I am running on are short and tight. I took the oneway out and installed a gear diff with 3000 oil. One of the other racers told me to run 30,000 in the front diff. Will this help me at all and why or why not?
Confused. I realize that the thicker viscosity will resist fluid movement and tend to be stiff.
#1647
Re: Diff Oil
and make it harder to control at speed. Using the heavier front diff oil will prevent the over-powering at the rear and make the car more stable ( more under-steer) and therefore easier to drive.
I talked to an ex-designer at Neo Racing and he thinks the rear suspension of MTX-2 makes the car tend to loose its tail or over-steer, and that's way Mugen spec 30,000 front and very light 5000 for the rear, to combat the tendency to over-steer...
Also, the stock rear springs are the softest and the front are the hardest, this dramatic setup is used to compensate having a loose rear end as well.
#1648
Re: Re: Diff Oil
Originally posted by yokomoracer
If your front diff oil is too light, your car will tend to over-steer
#1649
I use a front oneway together with a solid rear axle for a medium but tight in field track. The setup works pretty good !
The setting of the car's performance is not partcularly depends on one or two settings. Try different setup such as shock position, springs, caster/camber etc.
I will not go for 30000 in front if i have to use diff !!
#1650
Kawahara negative diff
Guys,
my Kawahara diff locked up on me yesterday. I built it w/o the white plastic washers as people recommended here, instead I used the metal washers from Mugen.
I use white Lithium grease and it feels very smooth.
After it locked up, I worked it a little bit and became free again.
Everybody else had a problem like this?
