Mixing different viscosity silicone oils? >
Old 05-30-2007, 05:39 AM
etgdpu's Avatar
Default Mixing different viscosity silicone oils?
Hello,
Is it OK to mix 2 different viscosity silicone oils, in order to create a new viscosity in between the 2. For example if you mix 50% 500cps and 50% 600cps, will the result be 550cps? I am asking because some people say that the 2 different silicones will not create an homogenous mixture, because the solution of one oil to the other is not possible. As a result a strange mixture will be produced and the shock piston will work at certain points with 500cps and at other points with 600cps during a move.
What is the truth?
Thanks in advance
etgdpu is offline
Old 05-30-2007, 05:00 PM
quietstorm76's Avatar
Go here...........
http://www.twf8.ws/php/index.php?opt...per&Itemid=175
quietstorm76 is offline
Old 05-30-2007, 07:38 PM
Paradoxmaker's Avatar
You can also use this site:
http://www.gesilicones.com/gesilwiza...l?SMSESSION=NO
Paradoxmaker is offline
Old 05-30-2007, 08:10 PM
rcabj's Avatar
well, now i know i was not totally wrong when i mix my diff oil
rcabj is offline
Old 05-30-2007, 11:28 PM
kcrunchone's Avatar
Now my secret is out on the table ! ! !
thanks a lot
kcrunchone is offline
Old 05-31-2007, 12:51 AM
etgdpu's Avatar
Thanks guys
etgdpu is offline
