Old 05-28-2007, 05:56 PM   #1
NitroMaxx3.3's Avatar
Trader Rating: 19 (100%+)
Default what oil weight??
what weight oil should i use if im going to be running yellow associated springs up front(35lbs) red associated springs(22lbs) in back of my ntc3. thanks
NitroMaxx3.3 is offline   Reply With Quote
Old 05-29-2007, 02:01 AM   #2
British Menace's Avatar
If it's a smooth track. I would go for 70WT front and 60 rear.
Bumpy track 50 or 60 front and 40/45 rear.
For Losi go 5 or 10WT less then those above.
Hope this helps.
If you have the time to test. Don't change any of your other set up details on the car and concentrate on rear oil first, then front.
Look for the way your car handles the bumps the track has to find what you need.
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
HOW MUCH WEIGHT DO I NEED TO ADD F N CUDA Electric On-Road 3 09-01-2007 11:50 AM
Oil weight ? ttr Rookie Zone 4 09-10-2006 03:07 PM
Weight of a HPI R40 jdcarbon Electric On-Road 2 04-24-2006 12:30 PM
weight of pt Xrayskid Electric On-Road 3 01-07-2006 03:46 PM
Weight? SPC Racing Electric On-Road 2 03-18-2004 03:27 PM
SEO by vBSEO 3.5.0
