tire truer
tire truer
http://www.brooklynhobbies.com/index...OD&ProdID=2314
does this come with everything i need to run it besides the 1/10 arbor i need?
Works pretty good.
Things you need to get: Arbor, I got and Integy from Tower Hobbies.
Things you need to have on hand when cutting: A caliper to make sure you are getting the right diameter. The measure system isn't exactly accurate.
Things you should get: Hudy bit. This makes the cut a lot smoother and lasts a lot longer.
This is a great truer for someone on a budget.
OFNA tire truer
I have this truer and it work pretty good for my low budget. But if you go pro and need to cut a lot of tires, go Hudy.
