Old 04-11-2003, 10:28 PM   #1
Default MTX-3 2 Speed Unit Adjustment
I am currently building my kit, and am stuck.
Can someone please explain the diagram in manual on page 9 about the 2 speed housing on the MTX-3
I really don't understand the diagram, and also why is there 2 screws with springs? I have a MTX-2 which was much simpler.
Do I have to adjust 2 screws at the same time to adjust the timing of the two-speed?
Also finally is still the same technique :- Tighter the screw is, the later the car shifts into second?
Thanks for your help
ttektek is offline   Reply With Quote
Old 04-11-2003, 11:17 PM   #2
sparksy's Avatar
Trader Rating: 14 (94%+)
Yes you have to adjust both screws. It is the same as the old one in terms of screw in to shift later...
Make sure you have both screws equally screwed in to start with.... screw all the way in then back out equaly. If you dont, the fly weights will not contact the drum evenly... which will cause slippage and wear unevenly
sparksy is offline   Reply With Quote
Tamiya TG-10mk2 2 speed adjustment qwkpony Nitro On-Road 2 09-21-2007 09:05 AM
clutch and 2nd speed adjustment g4s aussies1129 Nitro On-Road 5 08-04-2007 06:08 AM
what adjustment? peahbeez Electric Off-Road 2 05-08-2005 03:16 PM
TL-01 adjustment robborc Electric On-Road 3 02-15-2005 07:03 PM
SEO by vBSEO 3.5.0
