After Run oil
After Run oil
What is a good after run oil?
Where can I get it for a good price?
is the oil good on all nitro engines?
any help would be great thanks.
I use Hobbico After Run Oil. It seems to work just fine. You can get a 2 oz. bottle of it at your LHS for like $2.50. I use it all the time and I've had the same bottle for two years. It should work well in any nitro motor.
Re: After Run oil
You can find it at most major auto parts stores.
It also works in all nitro engines.
Take care.
After Run oil
Marvel Mystery oil is what alot of after-run oils are anyways. Much cheaper to buy it at an Auto Parts store.
Well over hear in australia we use castroll Dexton 3 automatic transmision fluid, and it works great because inside a transmission there is rubber seals , so it will keep your carby and motor seals looking like new excpecially your highly polished motor internals.
well for the price and avaiblility I guess i will get some Marvel Mystery oil thanks for the info and you are right POPS 1.95 for 4oz is a lot cheaper than 5 for the same stuff. thanks again.
Can't go wrong with Marvel Mystery Oil...been using it for over 20 years in various car and airplane engines.
I use the hobbico after run oil. Works like it should. BTW, it smells like candy cigaretts.
i use yamalube.....you cna get it at a yamaha motercycle shop.....it is what is used to fog their engines...it is great, and a can will last forever.....
tornado after run oils works really good as well
JordanC> sure there's remnants of oil left in the enine. The problem is the nitromethane that's in the fuel, too. It ATTRACTS moisture, and will overpower the castor oil left in there.
If you want an engine to last, use SOME sort of after run oil, I prefer Marvel.
