What is the average price for a Centex 2 Speed?
is $110.00 worth it? Included in the price are motor mounts, 22T & 26T gears and shipping.
That sounds about right. If you look around on Ebay you might be able to get a new one for around $70-80 if you're lucky. Most centax 2 speeds run upwards of $100.
If it makes any difference, I personally don't think it's worth it since you can make the lighten three shoe clutch with stiffer springs work just as good. The only place you'd really be gaining with the centax is at the start, where you can set the clutch to engage at high rpm, giving you a quick launch. Just my opinion though...
At Rev they start IFMAR style so a quick launch wouldn't be too beneficial since there isn't anyone you gotta worry about getting ahead of before the first turn.
Thanks!
I think you'll be fine with just the modified three shoe clutch assembly. A centax has it's advantages, such as precision clutch tuning, but that also requires precision adjusting equipment, plus a lot of patience to get it to work right. I would get one if they were cheaper, but I don't see wasting $110 on one if I can get something that works just about as well for about $20.
You don't necessarily need the lightened clutch bell, but yes just follow the instructions per the NTC3 thread and you should be in good shape. The lightened clutch bell will only get rid of a little bit of rotational mass, it won't affect the functionality of the clutch at all. Only possible thing it might add is a little bit of cooling for the clutch shoes, since I does allow at least a little bit of air flow through the clutch bell. I run a lightened clutch bell, but only because I needed a new one. I haven't seen a noticable performance gain since getting one...
Most of the ntc3's centax clutches are too small to provide any difference from a normal clutch. A properly tuned 2 or 3 shoe clutch will be just as good. And the weight of the centax is another drawback. Spend your money on something more useful such as an rd logics dual chamber pipe.
Ok Thanks!
You saved me about $115 bucks!
I can use that to look for a better motor...and dump this AE .12 when I get track time and learn how to drive Nitro...considerably different than EP...
Any motor suggestions?
The MT12's, the Nova Rossi 12's, and the JP modified 12's are all great motors. They will run in the $150-$200 range, but are all well worth it. I run an OS .12TR and I love it; it makes great power and gets awesome fuel mileage (tuned right, I can get 6-8 minutes off a tank at race pace without losing too much power).
Yes, get used to the way your 2-3 shoe clutch works then move on to centex when you get alot more experience. Centex clutches are great but you have to spend alot fo time and have to knwo how to adjust them correctly. Alot of keep up on them too.
I have an O.S. TR as well and I like it. Very good fuel efficientcy and a super smooth powerband with great power, almost too smooth. Right now I have a Mugen MR-12 S1 and it's a blast, alot more picky as far as tuning goes though. The O.S. is a great intermediate motor, but if you want more power get a Novarossi or Sirio, but be prepared to pull your hair out when you start tunign it. I've been so used to O.S. motors where they are very forgiving.
