Diff Oil?
Ok, I have a regular Kyosho V-One R, and I need to knwo what can I use instead of the stock rear diff oil setup. I just don;t liek the fact that you mix some of the stock 50wt shock oil and the 50000wt in a 1:1 ratio to make soem Mystery diff oil. Is there anythign that seems to be close to the the stock setup just more consistant. Like maybe 10000wt oil or something. I dunno. If you have any ideas it would be greatly apreciated. Thanks.
-Sushi Boy |
Re: Diff Oil?
Originally posted by Sushi Boy Ok, I have a regular Kyosho V-One R, and I need to knwo what can I use instead of the stock rear diff oil setup. I just don;t liek the fact that you mix some of the stock 50wt shock oil and the 50000wt in a 1:1 ratio to make soem Mystery diff oil. Is there anythign that seems to be close to the the stock setup just more consistant. Like maybe 10000wt oil or something. I dunno. If you have any ideas it would be greatly apreciated. Thanks. -Sushi Boy just go to your hobby shop and get some 10,000 wt oil theirs all different types of diff oil you can get |
You can do it that way, but it is best to stick with the stuff they've got on the counter, less of a pain and more consistent.
Yeah, The manual in the Original V-One R with rubber tires wants you to mix 50K oil and the 50Wt oil in a 50:50 mix for the rear diff. I just wanna knwo what this mixture is comparable too.
wouldnt be equal to 10,000wt
maybe 5000wt or 3000wt dont go by the book, find a wieght that you like and suits your driving style |
I lied the way it felt by the book, but I think I'll get some oils just to have in my box. 5-10K maybe. Thanks for your help guys. I know it might have been an akward question but everyone here on this forum seems to pull through for me. Thanks again. :D
-Sushi Boy:sneaky: |
Originally posted by Sushi Boy Yeah, The manual in the Original V-One R with rubber tires wants you to mix 50K oil and the 50Wt oil in a 50:50 mix for the rear diff. I just wanna knwo what this mixture is comparable too. 1 part 50,000 weight + 1 part 50 weight = 2 parts 50,050 weight ÷ 2 = 1 part 25,025 weight Simple . . ;) |
right..........
