default settings for rs4 rtr3
Since i am new to this I have been trying to tweak things out but i beleive i made things worse than better. Right now if i use the brake the car will stop running. the same thing happens while i am in the middle of running it as well. I tried to adjust the throttle idle, but i think i did it too much (not sure to much or to little) And as of right now i can't tell whether i'm running lean, rich or somewhere in the middle.
So i was wondering if thier is a way to get the throttle idle and valve needle back to factory settings? that way i can start over again.
try the hpi fourm the staff can tell you that info, i cant find anything on defaut settings for that engine
i will try the hpi forums. thanx for trying
