Mugen MTX-4R
#1697
But i am trying the new spurs and 2-speed thing and it seems to last a little longer. I wonder if there was any quality issue with the older spurs.
Hope this helps.
#1701
what throttle servo u guys recommend?
#1702
Trader Rating: 171 (100%+)
MUGEN MTX4R race ready
Hi I'm selling my MUGEN MTX4R with Ninja .12 Ninja Pipe the good one the twist and lock one also both srevos Airtronics $119 ones spare parts 2 Ti shafts all lite MSR pullies oneway and lock diff. Check it out on ebay item # 280242797509 thanks [email protected] REASON FOR SELLING MY LOCAL TRACK IS NOT RUNNING ANY NITRO FBF IN BROOKLYN
#1703
Anybody using a lippo as there RX pack, if so what Mah and what are the dimensions of the pack, looking at using one in the not so distant future
Cheer's Rob
Cheer's Rob
#1704
What can cause the rear belt to strip? I lost 2 rear belts in one gallon of fuel.
#1706
I have 2nd gear stripping problem and till date i still do not know what is the problem. I have changed and check everything from bulkheads, bearings, clutch bells, gear meshing, engine screws mounts, stiffer chassis, single engines mounts.. but still strip.
Hope this helps.
Hope this helps.
#1707
Billy
#1708
Iam using the Xceed 1300mah 2cell pack fits in the car easy
Dont no the actual size
But can measure next time I have it out of the car.
You will also need the 6.2v regulator
Lance
#1709
Lance where you get them from and how much damage is it going to be , just got my new Radio (T3pk with spektrum) came with a lippo batt, but noticed it doesn't have the balancing lead fitted, got te car sort of sorted out now, was clutch settings, replaced with ultra hard spring, grey shoe and also fitted the new option 2 speed, seems fine now and the engine sounds a whOOOOOle lot better
#1710
sounds good Rob
Shoot me a pm with your email addy and Ill forward you the details
