Mugen MTX-4R
#107
I just ripped apart both of my Prospec MTX3s, a MTX4, and my new MTX4R car and all two speed housings are the same as well as all of the DO603 thrust bearings for the clutch, its all the same stuff guy's.
#108
Sorry, my mistake. Have used the wrong word
They changed the clutch bell. The 3 ball bearing fits now better. When you look on the clutch bell, you will find a little white point on it, which marks the new one
#110
Assembly Help
I'm putting together a new -4R and it seems to me the front belt is wrong. When lining up the pulley aft of the one way I can only get about a third of the hole to show at best. I've got the tension adjusted back but it seems like I'm having to pull extraordinarly hard.
I know these should be tight but I don't know how tight is too tight.
Any thoughts?
Any thoughts?
#111
Newest member of the MTX-4R family
Just picked up my MTX-4R kit. Reading the manual now. For a first time kit builder, aside from reading this forum and nitro knowledgebase, any suggestions?
Thanks.
Thanks.
#112
Thanks.
Thanks.
#113
Any thoughts?
Any thoughts?
#114
Originally Posted by Sow&Steady
Yes, go to 3hobby.net of course and read the MTX4 build review. You can find it in the Content area under "Product Reviews". You'll find some handy tips on building the car.
#115
Thanks for the information about 3hobby.net. I have it bookmarked and have begun reading. I will be putting together my own build blog/team site in the coming weeks. I chose the 4R because it was the latest (well I guess the X-Ray NT1 is now the newest) proven platform. Hopefully this will bode well for a first time on-roader. I will post any question I have about the build, thanks.
#116
Belt to tight?
Thanks for the response. It wasn't that the belt was to tight my brain wasn't turned on. Make a note. Do not try to put something together on 4 hours of sleep. Helps to use the correct pulley.
I've got 5 hours in the build and it is a roller now.
I'm switching from a NTC3 to this. I can hardly wait to run it.
So far this car is just flying together. I can only work on it for a couple of hours at a time and the only thing that is a little weird is the packing of the parts. Not a problem once you figure out how they think.
Thanks Again
Thanks Again
#117
Thanks Again
Thanks Again
#118
Wow , just got a nice slap in the face. Mugen doesnt do any warranty work unless you have your reciept. So if you ever have any trouble on your car and theres no reciept. Your screwed. I unfortunately bought from acehardwarehobbies , which is now out of business. So I cant even get them to reprint it im sure.
#119
I open each package up and lay out all the screws on a clean white towel. I get to going on putting it together and that towel has saved me a couple of times when I drop a screw.
Are you supposed have extra parts when your done?
What's the grading system for left over parts?
6 or more better look it over again
3-5 not bad only one thing may fall off on the first run
0-2 go racing
0-2 go racing
#120
Yeah, I hear you with the towel thing. I did the same thing when build/rebuilding my T-Maxx and was stopping by Wally World today to pick up a big white beach towel for this build.
Quick question: Are you using a set-up station (Hudy, Integy) to get suspension set-up or just going with box stock to start (eye balling it)?
