Mugen MTX-4R
#3646
Location: Costa Del Sol, Marbella, Spain www.bradir.net
according to the owner, the DLS works well with rubber tyres at the moment. he´s still struggling with the foam setup which is kinda odd. too much grip maybe. will wait for more feedback from him.
#3648
#3649
What brake pads have you guys been using? Time for me to get some new ones. The standard mugen ones pretty good, or have you guys found something better?
#3651
Makes sense. Made for a 1/8 buggy, so they should stand up to a 1/10 car. What is the part # for those? Any modding needed to fit them?
#3653
hi,
does anyone know where can I get the new LM chassis that the guys used at the WC in Texas?
thank you
thank you
#3654
#3656
#3657
MTX4 on WC
Hi guys, do you anybody know, if MTX4 drivers on WC or EC used all original parts on some from another cars. There are rumors some used NT1 trany. I am only interested, cause specialy in Germany quite lot of drivers used MTX4 and are quite successful. Thanks.
#3659
Good luck
#3660
Not sure about nt1 tranny but tironi from italy uses sirio clutch and fukuda from japan has used xceed (sames as serpent) clutch also, both are direct fit with the offeref cltuch bell, as for the nt1 you can use it directly with some shims and spacers between the two speed housings with no issues at all, ive tried it and it works and if you can get a lowered engine mount better as these centax are all of them smaller than mtx stock one (1mm lower)
