Old 03-31-2003, 05:40 PM   #1
Default STS PRO 10 II opinions
Should I get the STS pro 10 II? I need your opinions, it looks really nice
xxrycecakexx is offline   Reply With Quote
Old 03-31-2003, 06:47 PM   #2
Its very fast on the straights, with the relatively free drivetrain what with the front one way and solid rear axle i.e; no differential action. Acceleration is also brisk, although this has more to do with gearing and engine powerband. On tight technical tracks, you'll have to adopt the jab-brake-jab way of driving....so, you might not be able to hold a smooth race line drive and the brakes are really only minimal.
Parts are cheap where I am, esp. if you compare to Serpent. I've taken to using STS Pro 2 parts for my Impulse. Optional diffs. are available for about USD60-80 if you find the one way and solid axle too hard to drive. Otherwise, the chassis is fully tunable. You can expect all the goodstuff like centax clutch and rear floating body mount. It is designed for high speed flowing tracks out of the box.
Morpheus2be is offline   Reply With Quote
I need your opinions! rcjunky10 Painting, Designs, Graphics and Photography 13 03-26-2008 06:10 PM
Opinions hardadz Electric On-Road 0 12-20-2005 04:58 PM
Need Opinions on Tuning My NTC3! opinions on my clutch/suspenion set up needed JDMboy Nitro On-Road 0 09-21-2004 09:05 PM
Opinions about used MT-12 rod_b Nitro On-Road 4 05-22-2002 04:18 AM
SEO by vBSEO 3.5.0
