Stuck Carburetor
Stuck Carburetor
My carb is stuck. It turns side to side in the crankcase but it wont pull out. What can I do to get it unstuck.
try heating the block of the engine up some using either a hair drier, or very very very lightly with a torch.
Have another look at the locking pin where the nut screws on......Take the brass nut off the pin and push the pin back and forth and try and twist off the carb. It should come off very easily. Dont force it, you may damage the seat.....
Cheers
Cheers
