Region 4 On Road Gas race at K Raceway in Kissimmee!
#76
bill G. call me,,,jackson,,my tyre truer took a dump!!!!!
#77
Originally Posted by GMartinez
Im ready but I am only racing Saturday since sunday is my daughter's B'Day
#79
Originally Posted by rocca30
hopefully the rain holds off, or thats what we all be doing. happy b-day to your daughter , george
Good luck to all & I hope it just passes thru
#81
Originally Posted by dj apolaro
- front -
40 wt 3 hole
-1 toe
1.5 camber
blue springs layed down
-1 droop
38 fronts to start 59.5mm
sway bar flat
1mm caster in front
lower roll center position
long steering ackerman
- rear -
40 wt 3 hole
+2 toe
3.5 camber
yellow springs third from the bottom
6 droop
40 rears to start 61mm
sway bar in 2mm
#2 position for roll center
use most camber gain in long position
diff 30,000wt
This is a starting point. See me this weekend if you need anything else.
Post any questions,
DJ Apolaro
40 wt 3 hole
-1 toe
1.5 camber
-1 droop
sway bar flat
1mm caster in front
- rear -
40 wt 3 hole
+2 toe
3.5 camber
6 droop
sway bar in 2mm
diff 30,000wt
Post any questions,
DJ Apolaro
Is that a locked or one-way?
#82
Originally Posted by trickd122
IT IS A LOCK
#83
WHAT DID YOU ASK FOR !!!!!!!!!!!!!!
IT IS A LOCK
IT IS A LOCK
#84
Just making sure
#85
- front -
40 wt 3 hole
-1 toe
1.5 camber
-1 droop
sway bar flat
1mm caster in front
- rear -
40 wt 3 hole
+2 toe
3.5 camber
6 droop
sway bar in 2mm
diff 30,000wt
Post any questions,
DJ Apolaro
40 wt 3 hole
-1 toe
1.5 camber
-1 droop
sway bar flat
1mm caster in front
- rear -
40 wt 3 hole
+2 toe
3.5 camber
6 droop
sway bar in 2mm
diff 30,000wt
Post any questions,
DJ Apolaro
#86
Originally Posted by Killa G
Have you been using the 3rd one way with your setup?
#87
So how was the racing this weekend guys?
#89
Well we got 4 rounds of qualifing, so there were plenty of chance to get a good run in, but on sunday we did not get to race. They called the race around noon, as it was still raining. The race ended with the positions going to how everyone qualified.
#90
DJ could u give us a run down on how the qualifing went and the positions where everone ended up
