Engine tuning
Engine tuning
hey guys,
now this is probly the worst question to you experts out there but i havent tuned an engine for quite some time, the high speed needle which way do you turn to open it clockwise or counter clockwise?
thanks
thanks
Rich is counterclockwise
Lean is clockwise
Lean is clockwise
hi! i'm using os 12tz p5 engine and have finished break-in. i've ran the car in the track, and after running the straights, i notice the engine would stay rev a bit higher than idle for 5-10 seconds after i release the throttle. my needle settings is still rich on the HSN and flush on the LSN.
i know its not the serv0-carb linkage as i've checked and it closes everytime i release the throttle.
anyone happen to know how to remedy this?
It sounds like the idle screw is in to far and the bottem end screw is rich giving you a "false" idle.
http://www.tsrcar.com/garage/paddock/engine_tips.pdf
Doug
Originally Posted by flack
I would recommend reading the article by Ron Paris...very informative.
Doug
Doug
thanks dough, got a reading and testing to do. you're right, article is very informative..
thanks again...
lean abit on high-end or rich a bit on low-end.
this 5-10 second will reduce.
Originally Posted by thamjk
usually this happen your tuning on high-end is richer then your low-end.
will test the tuning more this weekend...
thanks again flack
the article flack mentioned really helped. i ultimately found out i was on "false idle" as my carb idle opening was more than what was required yet the idle was OK. i've notice before i change the carb setting that no matter how i richen the low end, it would still rev high after releasing the throttle from WOT.
thanks again flack
thanks again flack
