Old 03-27-2003, 10:12 AM   #1
Default gears
i have a hpi nrs4 3 type ss i just curious what the best combination spur gears and tranny gears i can run i do run on track in a parking i do want a little more in take off but do not want to lose my top speed i was thinking of using 19t and 23t and for my spur gears i was thinking of using 39t and 43t give me some advice thank you
nitroblade is offline   Reply With Quote
Old 03-27-2003, 11:08 AM   #2
i dont know what gears it uses now but
if you want the same top speed leave second gear alone
if you want more acceleration you want to use a smaller clutch bell gear and/or a larger spur the opposite is true if you want more speed but less acceleration
you are suppose to keep the same amount of split between the gears meaning that if there is 4 tooth difference between spur gears there should also be a four tooth difference between the clutch bell gears
that is done so that the proper gear mesh is able to be accomplished on both first and second gears
jason102276 is offline   Reply With Quote
★ Robinson and Kimbrough Pinion Gears and Spur Gears - All NEW! ★ All-Star R/C Items: For Sale/Trade 40 01-21-2009 01:59 PM
WTB: Rc10t4 Spur Gears, And Pinion Gears Associated-08 R/C Items: Wanted to Buy 0 03-10-2008 08:19 PM
Lot of 14 Pinion Gears, 2 Pinion Holders, and 3 Spur Gears (64 Pitch) MyRCTrader R/C Items: For Sale/Trade 4 02-04-2008 06:08 AM
1/10th Pan Car Setup - CORALLY C10X - Gears, Gears, Gears? paul73rc Oval, Larger Scales and More 4 04-06-2007 09:10 PM
Layshaft Gears, Pinion gears for 1/5 scale.. MaxPower Oval, Larger Scales and More 0 04-08-2003 05:16 PM
SEO by vBSEO 3.5.0
