Foams or Rubbers?
Foams or Rubbers?
Just wondering what everyone uses foams or rubber tires on thier nitro sedan.
Foams or rubbers...
Depends where you are running and what you are using it for. For bashing around a parking lot with your buds then stick with the rubs, they last longer. The foams are usually used for racing on prepped surface, they are more proned to chunking if used on non prepped surface.
Racings what I meant, on smooth flat an swept asphalt.
Racing......
As most hardcore racers will say foams are the only way to go. You might want to invest in a tire truer, it might be expensive but if you race a lot it will save you money in the long run. Good luck in the track.
I run rubbers on my MTX-3.
I prefer rubbers because they last longer and you don't have to worry about overdrive, underdrive, chunking, and constantly changing ride heights.
Many people say racing with rubber sucks because they are constantly searching for a tire/compound that works, but at our track people use and stick to only three types of tires(Sorex 36, 40, Yok 138G series) so we know what works and what doesn't.
As for performance, several racers(including myself) are very competitive using rubbers in foam class. This could be because of our track size and design though.
personally i think its all in driving preference. no one give me any of this "if these conditions" BS. you drive foams because you want your car to hook up 100% of the time with very little give....IMHO that is gotta be the most boring way to race. i will only run rubbers because i want my car to hook but i wanna be abe to slide corners when i need to. you can with foams but its a little harder and chunks the tires i wanna have the break lose power to avoid the board bouncing n00bs. and i wanna be able to dial in my car at the local park
now im a little biased because ive been doing offroad for awhile and sliding comes naturally to me and so does the control
but the foams vs rubber seems all worth preference to driving and nothing more
sorry if thats a little harsh but i cant stand everyone saying "foams this and foams that" when its so much money and really has to do with how you drive your car
Originally posted by AndrewtheRCman
personally i think its all in driving preference. no one give me any of this "if these conditions" BS...
I have to agree with most of the remaining post, except with this...
The reason I don't run foams is that it costs too much for me to run every race, and I feel that the competition in the "stock-class" (rubber tires) at my track is more exciting and fun due to a relatively high and similar ability levels amongst my fellow racers.
I use foam for racing and rubbers for just bashing with the buds
I run rubbers on my SuperTen and foams when I race 1/10th.
