Setting up a receiver >
Old 02-17-2007, 04:13 AM
Arrow Setting up a receiver
Hi Guys
I am having a problem setting up my receiver for braking . When the throttle triger is at a neutral position the carb is set at idle which is fine. If I had to brake the servo goes in the other direction as to accelaration. Is this normal? because I don't see the point.
Thanks Shaun
shaun_dini is offline
Old 02-17-2007, 04:47 AM
If you're trying to brake and the servo pulls the carb open, you need to go into your radio (what radio do you have?) and reverse the servo direction.
darkangel is offline
