Old 03-16-2003, 03:21 PM   #1
Send a message via Yahoo to VRacer04
Default Engine Replace?
Does anybody know what parts you would need if any to put a .15SS engine in a Nitro RS4 3 RTR.
VRacer04 is offline   Reply With Quote
Old 03-16-2003, 04:38 PM   #2
popsracer's Avatar
Default .15SS engine in a Nitro RS4 3 RTR.
HPI .15SS, Pull Start, Rotary Carb, should be a direct bolt in for the .15FE. Just use the engine mounts and flywheel from your 15FE.
If you buy a NON-Pull Start Engine, you will need a Starter Box to start the car. Other than that, everything will interchange with your 15FE.
BTW, FANTOM Racing has a Pull Start .15 engine that will fit, is very fast and usually less expensive than the HPI engines. They are both made by the same company.
popsracer is offline   Reply With Quote
XTM diff??? I want to replace them! Daddydan Nitro Off-Road 0 07-06-2007 09:32 PM
brushless what to replace Rasmus TbEvo IV Electric On-Road 3 01-22-2006 09:09 AM
is it still worth to replace? rc_square24 Electric On-Road 3 08-14-2004 02:29 AM
Help! Should i just replace P/S or whole engine? US_MATRIX Nitro On-Road 4 03-02-2004 07:04 AM
RS4 3 RTR Engine Replace VRacer04 Nitro On-Road 4 03-18-2003 07:48 PM
SEO by vBSEO 3.5.0
