EVO WCE vs EVO Standard
Season greetings,
Can you all tell me what are the differences between the V-ONE RRR Evo and the V-ONE RRR Evo.WC Team Edition ??
And what would it cost to move from the basic Evo to the WCE Evo ???
Alrighty, here is the xtras:
Sealed bearing (6x10x3mm) x 2 <BRG022>
9 Ball screw <FM337>
Adjustable rod set <SPW5>
Universal swing shaft (rear) <VSW015>
Muffler stay holder <VZ086>
Drive washer set <VZW010>
Universal shaft set (RRR) (front) <VZW219>
SP Drive belt 189 (RRR) F <VZW201>
SP Drive belt 384 (RRR) M <VZW202>
SP Drive belt 180 (RRR) R <VZW203>
FRP Battery plate (V-ONE RRR) <VZW208>
FRP Middle plate (V-ONE RRR) <VZW212>
Aluminum Collar (2mm) <W0142>
Shock ends <W5015>
3D Lightweight flywheel (33mm/VS029) <VSW043>
Titanium coated shock shaft (30) nut type <W6002>
Hollow middle shaft (V-ONE RR Evo.) <VZW056>
Rear adjustable stabilizer set (RRR/RRR Evo.) <VZW204>
Lightweight 1st gear housing (V-ONE RR/RREvo./FW-05) <VZW064>
One-piece engine mount <VZW065>
Carbon front shock stay (RR Evo./RRR) <VZW064>
* Number inside < > is item number.
I think the price difference is like $100 Aud.
Hope This Helps
Shock ends <W5015>
Hope This Helps
If it's within your budget, get the WCE Evo. The universals and one-piece engine mount are "must haves" for the RRR and the other upgraded parts are nice to have from the start. In the long run, it's worth the extra money.
Thanks guys for all the information, I will try for the WCE, it seems I will save in the long run
It sure does look like a great package. Am waiting for it to be sold here so i can upgrade from my VoneSIII. What do you guys think is the best controller package for this setup (M11 vs PKsuper vs Ex10 helios) and what is a good engine /tune pipe combo?
Location: Cebu City, Philippines and Ocala, Florida, USA
Well, EVO WCE is my choice. It already includes lots of hop-ups that you will need in the long run. It cut down on the cost since getting the hop-ups parts piece by piece will cost more
SIRIO
Try our Sirio engines and pipes. Excellent combination when used together!!
hmm
Hi, i am still browsing for my first nitro kit, i saw V1rrr wce, evo and evo wce. what are their major diffrence? the wce kit i saw is around aprox usd350 same price as evo, the evo wce is kind of expensive at usd475
Is the v1rrr wce still a worthy car to get? or the evo will be better than the wce (not evo wce). thanks
engTat
engTat
engTat
engTat
Originally Posted by Scott Fisher
If anybody knows where there is a new EVO WCE kit available, PM me please and let me know.
