Handling problems on a NTC3
What settings should i use for a NTC3 on a tarmac surface and i am using Sorex 32 Front and back, Type C Firm-Front, Type C Medium-Back? any ideas?
help me too please!
hi i also drive in the carpark where MDS drives and i too find my handling bad mainly out of corners! the carpark is quite rough any suggestions!
I don't run rubber tires, but what's the problem?
Handling Prob
Hi It is ok going into the corners but it is when i exit them, as soon as i hit the throttle is spins like a donut, any help,
my setting are :
Toe in: Rear 2* Front 0*
Camber: 2* All round
Caster: 90*
Shocks: Quite stiff
Also my car wheel spins off the mark so how could i cut down the wheel spin to gain more acceleration.
Need help?
my setting are :
Caster: 90*
Shocks: Quite stiff
Need help?
how do donuts spin?
Run atleast 3 degrees rear toe, and 3 camber up front at 4+ in the back. Also try running reds all the way around with no rear droop (remove the screws) and 4 up front.
Registered User
Try the diff settings, run the front diff tight to 1/8th turn out, loosen the rear diff to about 1/4 to 1/2 out. Put less droop in the car try maybe -3 to -4 droop, front and rear , 0 droop will give you less traction to the rear of the car.
