Kyosho GXR.15
Kyosho GXR.15
Hi
Just wondered if there is any problems mounting a Kyosho GXR 15 engine into another chassis that uses normal engine mounts. I am not sure if the cast engine mount on the bottom of the crank case would interfear with a normal profile engine mount like that on a NTC3, CD3 etc.
Yes there is, but you can buy a motor mount so that you can put the engine on other chassis.
Is there anyone that can assist me?
I look forward to your feedback.
u need to be careful of which mounts you buy. My 3-racing mounts were like 1mm shorter than the mounts on the engine. Even so you could just dremel the extra mm off
