Old 01-25-2007, 09:08 AM   #31
Ivan Dickson's Avatar
Trader Rating: 3 (80%+)
Thumbs up
Real true talk about owning a 1/8 scale you hit it right on point llamont
Ivan Dickson is offline   Reply With Quote
Old 01-25-2007, 01:12 PM   #32
flack's Avatar
I have loosely followed this thread as I am making the switch from 1/10 to 1/8. Below are quick costs from a online retailer. (shipping and tax not included):
1/10 1/8
serpent 720 = $410 Serpent 960 = 510
Mega M12 Power Pack = $295 DSII Power Pack = $400
(included engine & pipe) (included engine & pipe)
Body = $20 Body = $35
Radio = $200 - $400 Radio = $200 - $400
Servos = $120/ea (2 req.) Servos = $120/ea (2 req.)
(you won't use cheap servos in either class)
Tires = $22 for set of 4 Tires = $35 for set of 4
TOTAL = $1387 TOTAL = $1620
Not a huge difference. Parts probably will be 10% more from 1/10 to 1/8
Fuel consumption would be:
1/10 75ml
1 gal = 3785ml
You would get 50 runs at $25
1/8 125ml
1 gal = 3785ml
You would get 30 runs
You would have to buy 1.5 gals to equal 50 runs.
Cost would be $25 + $12.5 = $37.5
1/8 is definatly more expensive but not the extreme expense some would like you to believe. You can spend as much or as little in either class. Mod engines, foo hop ups....it is what you want to spend.
flack is offline   Reply With Quote
Old 01-25-2007, 01:26 PM   #33
Good info all around thanks guys.
I asked a guy at my LHS who also races whether I should do 1/8 or 1/10 and to explain the differences.
He put it like this...
"Basically they are the same cost wise. Give or take a few dollars for the kit, most hop-ups and engines are within the same ballpark. Radios would not be any more costly between classes. Alot of people think 1/8 is more expensive but it's about the same. If you want to compete you won't be using cheapo parts so the cost will come in to play with 1/10 too. 1/8 is however, faster. The cars can achieve higher speeds and higher cornering speeds, but there is a catch. In this area (talking about locally here) There is not a great selection of tracks to accomidate a 1/8 scale race. You can run your car on a small local track even if it's 1/8, but you won't get the feel of the car and the performance it's capable of. There would be no room to open it up even if you dropped the gearing down etc. (there's only 1 track I know of that is large enough to accomidate 1/8 fully and it's about an hour to 1.5hours drive from my house)."
So basically he recommended 1/10 because the tracks around here are not huge so a 1/8 may not be the best choice unless I'm willing to travel pretty far every weekend or whatever.
That's actually something I didn't know. I didn't know how many tracks there were and now that I know I think 1/10 will be a better choice because there is more spots available to race. I also heard that not many people show up to the local club tracks with 1/8. Maybe just for some fun, but no races.(not enough people)
Dredd is offline   Reply With Quote
Old 01-25-2007, 01:36 PM   #34
gashuffer's Avatar
Trader Rating: 48 (100%+)
Have fun and enjoy.
gashuffer is offline   Reply With Quote
Old 01-28-2007, 03:17 PM   #35
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Hey Dredd you run at Floyd Bennet too right? I was in your situation once and bought my MRX4 package at my LHS a while back. It costed me $870 or so for everything minus servos as I got some basic stuff. The motor though was old (novarossi top PT21 SP1), but when tuned properly allowed me to run with anyone else out there. One thing was certain was that the tires on the 8th, the stocks and the Spider tires, lasted me a heck of a long time. With less power than the others I didn't have as much wheel spin and the way you drive also contributes to tire longevity.
After running my 8th and sedan, the 8th stood upto crashes a heck lot better than my tourer. So far I only busted a knuckle after being hit by a beginner, and toasted 2 rear belts at BPT track which is notorious for debris lodging in the rear hubs of 8th cars. The only amount of $$ I spent on my 8th was for one set of tires, a JR servo, and a few parts that I thought was more beneficial to buy. My sedan, which isn't a mugen, nor was hopped upto max factory specks costed me more $$ in the long run. Sure a Mugen sedan is tough too, but it's not indestructable. I seen others get into wrecks, but just not often.
As said both can cost about the same, but on a small track, a sedan will be cheaper as you don't have to dish out a lot for a powerplant. At the regionals I saw guys running stock .12TZ and ran with everyone else some making the A main even. I ran the OS .12TR and made 8th in the B main for touring that day. Not bad for the weakest motor on the field. I also try NOT to break anything and if the car seems to be sliding towards a board or lost traction in any way, the brakes are applied...enough to keep me from being hit. You can always catch up later on in the race and regain your position.
One thing though, that RTR XR8 will cost you a lot to upgrade to, so why not get the pro kit? It's under $400 and very reasonable. In BPT CT Aces stocks plenty of parts for that car and even the LW alloy arms which I saw few guys running. Dean (BPT DEAN associated with Bpts kit club), runs that car also with some of those parts and I must say his XR8 is down right FAST with the Vega Scud .21. The narly wrecks we had too practicing there did nothing to his car. The XR8 is definately a car to start in 8th, but if parts are limited, do it right and go with one of the Big 3 (Mugen, Kyosho, Serpent). I run a stock MRX4 and like it a lot. I may not even change to the R specs even, but it'd be something to try as everyone who went with them had all positive feed back. Both classes can be expensive, or inexpensive, but overall you will need a tire truer and setup system for both. I'm debating on what car to run mainly this year myself as both are ready. The sedan still needs to get it's setup gauges and the 8th needs a race motor as I'm buying a practice motor from a friend. Whatever you do, don't do like I did and run both classes on one day. Never had to hustle so hard, but I enjoyed every bit of it.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Please help my son decide... glock19er Monster Trucks 16 08-22-2007 06:23 PM
Help me decide natskiboy Electric On-Road 13 01-06-2006 08:49 PM
need help can't decide what to buy next classic xl Monster Trucks 6 08-13-2005 12:46 PM
help me decide! kh15 Electric Off-Road 15 01-05-2005 11:13 AM
Help me decide what to get...... RoadRat Electric On-Road 4 05-18-2003 04:55 PM
SEO by vBSEO 3.5.0
