Old 01-03-2007, 12:55 PM   #16
Built B16A's Avatar
i re-sealed the shocks, removed a spacer.. added -1 d toe in the rear, and -1 d toe in the front.. tight in the front.. tight in the rear.. running the Dodge stratus shell with a spoiler.. and im still having a rear end issue.
its almost as if when i spin the motor at high REV, it wants to push the car sideways.. anyone have any advise?
Built B16A is offline   Reply With Quote
Old 01-03-2007, 04:15 PM   #17
TC_Tuner's Avatar
Trader Rating: 34 (100%+)
Default .
First, set the camber on all four corners to something like 2 degree. basically, when you look at the car (at eye level) from behind, the wheels should look like this / \ Obviously, not that much, but in that general direction.
Front toe can be -1, 0 or + 1. as Long as your in the ballpark, I don't think this is causing your problem.
I think you don't have enough rear toe in. I would start by trying 2 to 3 degrees of rear toe.
You don't need spendy setup gauges for this - just use the plastic AE tool (Set the car vertically on the bumper to check toe with this gauge).
Are the suspension arms level, or is your ride height higher than that? If its higher by much, you might need to find a different (smoother) surface.
Yes, body choice as well as a rear wing will make a noticable difference. In your case, the wing is the biggest factor.
Also, check to see that all four wheels are getting power. Things like damaged drive cups, missing pins in hex adapters or damaged outdrives can cause this. Be sure to not overtighten the wheel nuts. This could cause binding and cause bad handling.
good luck
Airtronics | Byron's Fuel | Pro-Line | OS | Kyosho | Ballistic Batteries | Al's Hobby Shop
MRX4-X F180 Cobra Zipper Kart Yokomo BD Cup Racer FM1e Recoil M18 Pro Scalpel dNaNo Baja 5b SS 5T HB D8 Vorza ERevo Savage Flux SCX10 GT2 T4 Slash Ten SCTE Blitz ESE HB Cyclone D4 Mini ERevo Vendetta ST Mini T Micro T
TC_Tuner is offline   Reply With Quote
Old 01-03-2007, 04:43 PM   #18
Trader Rating: 15 (100%+)
Read through the email I sent you and it will have alot of things to check.
THE DOCTOR is offline   Reply With Quote
Old 01-04-2007, 01:20 AM   #19
Built B16A's Avatar
DR. man, thats alot of advise.. im gunan have to print that out, and read it to understand some of it.. lol
im gunna take some of the tuner's advise, and see if i can't get this nitro whipin again.. i can't understand it.. 2 weeks ago, it was running tits up, and now whenever i wind it up, wants to take off..
ive eliminated the body, im back to my stratus shell. ive softened up the rear shocks.. only thing left is more toe, and alittle camber.. (try to run 0d everywhere to save tires)
Xray t2 Multi Diff Settings CREWMAN Electric On-Road 3 04-18-2008 08:36 AM
Diff settings jordan.norwood@ Electric On-Road 1 07-08-2007 02:01 PM
Diff settings? TRFTIM Electric On-Road 4 12-15-2006 01:50 AM
DIFF SETTINGS wolfman76 Electric On-Road 3 08-02-2005 04:03 PM
Diff settings? Sleighty Electric On-Road 2 08-27-2003 08:30 PM
SEO by vBSEO 3.5.0
