EVO WCE vs EVO Standard >
Old 01-24-2007, 12:32 AM
  #16
Trader Rating: 17 (100%+)
hi, the rrr wce and rrr evo price are the same, do wce needs more upgrade or the evo?
Engtat
EngTat is offline
Old 01-24-2007, 12:57 AM
  #17
rmdhawaii's Avatar
Engtat
There are basically 4 RRR models:
RRR -> RRR Evo
RRR WCE -> RRR Evo WCE
My RRR Web site compares the RRR WCE with the RRR Evo in the "Kit Info" section. As you will see, the WCE has a lot more upgrades - but certain parts of the Evo are just different from the RRR or RRR WCE. Best thing to do, is to go through the manuals and compare the differences for yourself.
Once the English RRR Evo WCE manual is posted on the Kyosho site, I'll add it to the comparison chart.
rmdhawaii is offline
Old 01-24-2007, 01:02 AM
  #18
Originally Posted by twiggy
i would reccomend the evo over the rrr wce cause the shock springs and bodies are much better in the evo than the wce. also in the evo the main shaft is easier to pull apart and the brake pulley doesn't wear out like the plastic one did on the wce.
Really?
The RRR WCE didnt have a plastic one. It was alloy.
rcrossco_1 is offline
Old 01-24-2007, 01:13 AM
  #19
rmdhawaii's Avatar
Originally Posted by rcrossco_1
Really?
You are correct. The RRR WCE has an alloy brake pulley.
Old 01-24-2007, 08:04 AM
  #20
robert maestrey's Avatar
No it does not.....the RRR WCE has a plastic pulley that connects to the shaft via a pin...the brake adapter is metal....
By the way RRR EVO WCE that I have completed feels very nice....the shocks are silky smooth as others have stated....the weight of the car feels like its proportinally balanced better then the RRR...the car will see the track for the first time at the W-Nats...
robert maestrey is offline
Old 01-24-2007, 08:21 AM
  #21
teabag's Avatar
RRR -> RRR Evo
I think you have the RRR Evo and RRR WCE backwards, I think it goes:
31257 = V-One RRR
31258 = V-One RRR WC
31259 = V-One RRR EVO
31260 = V-One RRR EVO WC
Which is why I think someone commented the EVO has some better things than the WC.
teabag is offline
Old 01-24-2007, 08:25 AM
  #22
SOLOARTIST 702's Avatar
Default hmm
best to just get the latest model you'll be set
SOLOARTIST 702 is offline
Old 01-24-2007, 08:37 AM
  #23
31257 = V-One RRR
That is correct....the way you have laid it out.....
Old 01-24-2007, 09:31 AM
  #24
rmdhawaii's Avatar
31257 = V-One RRR
Backwards?
The Evo is an evolutoin of the RRR. Like the RRR, it has dog bones, two piece engine mount and a bunch of other plastic parts - but it does have some new parts and the servo layout is different.
The WCE has all the upgrades that the RRR and Evo are missing.
Evo WCE has the evo parts plus the WCE upgrades.
That's what I meant...
Old 01-24-2007, 09:56 AM
  #25
rmdhawaii's Avatar
You're right Robert. The WCE has a metal brake adapter and plastic pulley. When someone referred to "brake pulley" in the context above, I thought they meant the brake adapter on the WCE. The brake adapter and pulley on the Evo is the same part!
By the way RRR EVO WCE that I have completed feels very nice....the shocks are silky smooth as others have stated....the weight of the car feels like its proportionally balanced better then the RRR...the car will see the track for the first time at the W-Nats...
Hey Robert, I got dibs on an interview with you after the W-Nats regarding the car. Then you can break it all down for us. Make sure you keep good notes.
Old 01-24-2007, 10:02 AM
  #26
teabag's Avatar
Backwards?
I see what you meant, I was just going by kit part #'s. I've been trying to sort this whole thing out for awhile to determine which kit to get. I was assuming each release had everything the previous model release did and added more parts, but thats not correct.
So then in your opinion, which kit if you couldn't afford the latest EVO WCE, is closest? The RRR- EVO or RRR- WC.
teabag is offline
Old 01-24-2007, 10:13 AM
  #27
Trader Rating: 32 (100%+)
Whats a good price for the WCE EVO version?
racenut123 is offline
  #28
rmdhawaii's Avatar
If you get the RRR WCE, you don't have to upgrade anything. You can race it "as is".
If you get the Evo, at a minimum, you would have to purchase front and rear universals. I would highly recommend getting the one-piece engine mount as well.
As your budget allows, you can always upgrade the Evo to the Evo WCE spec. And you could always covert your WCE into a Evo WCE as well.
Bottom line is, all the parts are interchangeable between all four cars.
Old 01-24-2007, 10:28 AM
  #29
is 439.99 a good price for an evo WCE RRR?
Old 01-24-2007, 10:31 AM
  #30
No problem will do that..
