Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 07-11-2009, 02:18 PM   #4276
Nitro-Racer*'s Avatar
really what should i check, and isnt the yellow shoe suppost to slip and the white one to just not slip on acceleration??
Xray Nt1-Novarossi 3sct-KoPropo-GRP-Altis 2.3-RB Fuels
Xray 808 09-RB Killer 9-Hitec-KoPropo-RB Fuels
Nitro-Racer* is offline   Reply With Quote
Old 07-11-2009, 03:10 PM   #4277
musti72's Avatar
I experienced as opposite.
Mustafa Alp
musti72 is offline   Reply With Quote
Old 07-11-2009, 08:49 PM   #4278
Chubba's Avatar
the yellow shoe is a harder compound so does not slip as much and has a higher grip on the cluth bell. The original white one wears down a lot faster and tends to in my experience to slip more as less bite on the clutch bell.
Xray NT1 2009 Spec | RB T9 / GRP | Tornado Fuel | Futaba 4PK | GQ Tyres
Serpent 966 | Novarossi / GRP | Tornado Fuel | GQ / GRP Tyres
Chubba is offline   Reply With Quote
Old 07-12-2009, 04:13 AM   #4279
ok then why does my clutch slip, what should i check?? and also can you point to me musti72 when this happens on the video??
Old 07-12-2009, 07:54 AM   #4280
asw7576's Avatar
The video clip is choppy..... IF I watch the video clip AS IS, yes, your clutch is slipping. The engine is screaming, and your car is not moving as quickly. There is late factor ( not responsive to throttle input )
Loosen the centax spring locknut by half turn.
Do you shims correctly the clutch gap and end play ?
On roads || Xray nt1 || Mugen Seiki mrx4-r, mtx4, mtx3 prospec || Tamiya msx, m03, m04 || Yokomo mr4tc-bd || Associate L4
Off roads || Xray xt8 || Hobao hyper8
Radio || Futaba 3pk & 3pks
Old 07-12-2009, 09:31 AM   #4281
musti72's Avatar
You should also check your clutch spring, it can get old and become softer, so it can not push the shoe hard enough to bell.
Sanding the shoe and bell where they meet together, or replacing them with new ones would be a solution as well.
Mustafa Alp
Old 07-12-2009, 02:44 PM   #4282
i am pretty sure that the clutch gap and end play is correct, so i will losen up the spring a little, i am using the hard spring, maybe that is why it is not engaging early and the respond is not quick, will be checking the clutch tomorrow and will certainly sand down a bit the clutch and the bell. thanks for the respond guys
Old 07-13-2009, 07:31 AM   #4283
OK found the problem the clutch shoe is toast!! and the preload spring was unscrewed from its place, can this problems occur when running on a dusty tracks?? really strange, will keep an eye on the clutch in the future
Old 07-13-2009, 02:00 PM   #4284
aizenbelle's Avatar
Smile
and I was thinking that was the way you drove Dust is the worst enemy for your car and engine.
Don't Blame it on the car when you know you cant drive
X_ray Nt_1 08
RRR WC (For sale!!)
G4+EVO
G4RS 09' (IT'S FINALLY HERE!!!!!) Serpent 733 put on hold!!
aizenbelle is offline   Reply With Quote
Old 07-14-2009, 02:23 AM   #4285
asw7576's Avatar
I think you mixed up on that sentences. The centax spring push the clutch shoes towards flywheel.
The problem with soft centax spring is bogging. The clutch engage at lower rpm, creating bogging effect.
Old 07-14-2009, 04:53 AM   #4286
musti72's Avatar
No, I mean when spring is too soft, shoe touches the bell very softly, so it causes slipping. If it doesnt slip, engine will bog because of low rpms. Thats what I think.
Mustafa Alp
Old 07-14-2009, 03:27 PM   #4287
Originally Posted by jelayne View Post
[High Dynamic Clutch] What is the Advantage and where would it work best ??? I am seeing Nexus has it in stock
Anyone? I'd prefer to know what it is before i order .
JHIH is offline   Reply With Quote
Old 07-14-2009, 04:34 PM   #4288
Ron Goetter's Avatar
Send a message via AIM to Ron Goetter
From what I was told it works well on low bite tracks since it has the tendency to slip more then a standard clutch. But I've yet to actually use one so thats all second hand info.
The Goat... "Official" delivery service of express motorsports....
-Express Motorsports-Parma/PSE-Eb Mods-Lucky 7 RC-Trains and Lanes-answer-rcusa.com-CR Graphics-TQ Wire-
Horsham RC- rugburn anyone?
Ron Goetter is offline   Reply With Quote
Old 07-15-2009, 10:27 AM   #4289
musti72's Avatar
I have seen the clutch on Dirk Wischnewski's car(BumodGP champion) and believe it improves acceleration and its lighter. Mine is coming so Im going to give it a try this weekend. (Bumod is a HUGE track with medium grip.)
Mustafa Alp
Old 07-15-2009, 04:22 PM   #4290
mrgsr's Avatar
I would advise to blow the track first with a blower
HEI - Team Magic G4RS 09 - Novarossi - Kickass Racing - Tornado Fuels
Twister tires for 1:10 touring car for sale !
mrgsr is offline   Reply With Quote
Forum Jump
FS - NEW !!!! XRAY NT18T and XRAY NT18 plus HUDY micro truck starter box w/ battery Omarko Australia For Sale/Trade 2 06-25-2008 07:47 PM
Xray T2, Brushed Motor Combo, Setup Tools, Xray Springs, Bodies etc... GroffBall R/C Items: For Sale/Trade 13 09-23-2007 07:53 PM
WTB: NIB Xray T1FK05 & Xray Teflon coated aluminum Shock Body Adam.A Australia Wanted to Buy 4 01-02-2007 02:30 PM
WTB: Xray T1FK05 & Xray Teflon coated aluminum Shock Body Adam.A R/C Items: Wanted to Buy 1 12-30-2006 02:26 PM
XRAY sedan spring kit / XRAY multi-diff / PRS 114t spur / RR 64p pinions / Stratus evostyle R/C Items: For Sale/Trade 6 12-19-2006 08:33 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
