Xray NT1
#3946
#3948
Any pics on this mod?
#3950
Just running the standard spectrum reciever not the mini size you can get these days. I ts a tight fit but it does fit even with a lot of the wires stuffed in there as well,just take your time and try a few diff configeration and you should get it in the end. Certainly better than having it where the guy in the photo has got it,you only have to get some doofus pitting for you that misses the fuel tank more times than he gets it and, FIRE FIRE
And too bad for you that you have someone pitting for you who is a doofus, i don't.
It's pretty easy, just cut a bit of foam out at the bottom of the bumper, then you can put the weight between the lower bumper plate and the bumper itself. I run 25 grams of lead in the front.
#3953
#3954
On the NT1 08 I had the same problem, I have tried too cut down the white shoe in pieces with and without holes.
The shoes without holes seems inconsistent.
I like an agressive clutch, does somebody else have any thoughts on this.
Thanks.
#3955
for the people who are saying that you need 20grams of extra weight at the front, just buy the hard foam xray bumper. it is approx 20 grams heavier than the stock one, problem solved, used with the wider plastic bumper you should get the extra weight easy.
regarding the regulators. Novaks regulator is probably the smallest. i have a spectrum micro and the novak and it fits exactly in the footprint of the mugen mtx4 reciever holder. i've modified my NT1 to fit the mugen holder onto the xray CF reciever plate to reduce weight. (you need to drill a hole in the plate, and use a screw to hold the mugen mtx4 cover and the mount).
#3956
The flywheel is new (was the shake down of the new nt1 09).
Thanks.
Thanks.
#3957
TomB is the only driver i know that puts parts from all sorts of cars to the brand lol
#3959
Have you run the car with the weights in it yet? I also used weights attached with servo tape, and the weights got chucked all over the track. Combine that with a little spilled fuel which dissolves the glue on the servo tape, and you have a mess on your hands.
