I've tried something a little different rebuilding the diffs w/o the orings. Instead of using the o-ring, I instead spread some Red permatex silicone on the edge where the o-ring sits. I'm careful to make sure the area is clean(denatured alcohol) so the silicone will adhere. You need to use just a tiny amount of silicone. Once the diff halves are put together I use an exacto knife to remove excess silicone, and to seal the edge. I also make sure the silicone edge seals just the seam where the two diff halves come together. This has made for a diff that doesn't leak, and makes for easier rebuilds. In rebuilding, the silicone maintains it's integrity and it's easy to simply change the oil and put the two halves back together w/o the fear of distorting the now oil saturated o-ring or needing a replacement o-ring.
yep i've been doing this as well, works alot better than those o rings. no leaks. excess just comes out of the diff/oring area if there is any.
with the CF pads, they work great. i've been using the KM racing ones, but i think that KM racing OEM's for other companies anyway, so they are all the same. (the KM racing pads had black brake fibre pads though, not the cream coloured ones pictured.
www.rcunderground.net
EL PUEBLO UNIDO JAMAS SERA VENCIDO!!
built from the grass roots up!
Gano el SI!, Y asi va ser para siempre ;)
www.moorebankraceway.com
"I see lapped people"...i have xray vision.
Kawahara Tires
FRONT WHEEL 30mm width
REARWHEEL 40mm width
the best tyre around too
This is my xray nt1!
There are many other xray nt1's like it, but this one is mine!
Without my xray nt1,I am nothing!
Without me, my xray nt1 is nothing!
pop corn anyone or maybe some fairy floss
Im newbie with NT1
I would like to know a bit on the multi diff.
Anyone experienced with the Solid One-way configuration? I mean without the pin, so it is not solid and in the same time one way, same tires spinning on power, off power freely spin but same speed left and right becoz its attached to each other... geez.. im already confused just by explaining it
I have tried the front 80K diff and one way.. and now trying this solid one way method. Anyone can help me what will be expected? I know they will be no brake for sure. Is there any advantage?
thanks in advance.
I haven't found a single time i actually used the solid one way... my normal setup is diff but the spool is growing on me..
|Team Xray | RC America |MAX Engines | SMC | Hudy |Jaco | KO PROPO |"From Slovakia with Love" 009 |
Hello, I see some of the guys run very smooth hairpin turns with very punchy acceleration. How could I set my NT1 to be like that? I tried to use the silver spring not tightly with white shoe so I can have a gentle engagement but I still can't go around the corners like them.
I see they go into the hairpin with top speed, brake and turn around the corner with no stopping or slowing. How do they do it?
Is this a clutch setting or my throttle control ....
Serpent 960-08 + Max XL9
XRay NT1 + Max XXL3
CRC Gen-X + Novak Brushless 4.5
