Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 02-27-2008, 08:59 PM   #2746
Default 'Soft' parts
Today I met an owner of one of the first NT1s to come out. He said that the pivot balls and other screws would often come loose because the NT1 plastic is too soft. I just finished building my NT1 2008 version last week and wonder if there is something I should do to prevent parts from coming loose. Any 2008 owners have this problem? Suggested solutions . . .
going4#1 is offline   Reply With Quote
Old 02-27-2008, 11:32 PM   #2747
Loc tite blue. It will keep them from moving but still allow you to disassemble when necessary. use only a small amount or it will make a gunky mess. I usually put a drop on a piece of paper & then snag some with a tooth pick. Make sure you get the BLUE. They make a red formula but you can't disassemble with the red stuff.
GBagRacing is offline   Reply With Quote
Old 02-27-2008, 11:51 PM   #2748
TomB's Avatar
what is the spring rating of the stock silver nt1 springs?
www.rcunderground.net
EL PUEBLO UNIDO JAMAS SERA VENCIDO!!
built from the grass roots up!
Gano el SI!, Y asi va ser para siempre ;)
www.moorebankraceway.com
"I see lapped people"...i have xray vision.
TomB is offline   Reply With Quote
Old 02-28-2008, 12:00 AM   #2749
CIMRI's Avatar
Front: 338185 Spring-Set - SILVER - D=1.8 (33 LB)
Rear: 308396 SILVER (STOCK) D-1.7 28lB
CIMRI is offline   Reply With Quote
Old 02-28-2008, 12:05 AM   #2750
TomB's Avatar
cheers, ok, the fronts are stiffer than i expected. so stock springs are equivalent to a light purple front and a violet rear.
damn. i got the wrong springs then. i need the heavier ones
Old 02-28-2008, 06:10 AM   #2751
teamgp's Avatar
Spring Chart
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 02-28-2008, 05:04 PM   #2752
Osiris 75's Avatar
What is the difference in handling between a lock and a spool?
XRAY NT1 / RB CONCEPTS / MAX POWER XXL3
SPONSOR: ROCKET SCIENCE FUELS
KO PROPO RADIO/SERVOS
Osiris 75 is offline   Reply With Quote
Old 02-28-2008, 05:08 PM   #2753
D-nicest's Avatar
There is none, both are solid
Diatta Collymore
Team RC America, Team Epic
Xray/Hudy/Jaco/Max Power/KO Propo
Byron Gen 2
Bruckner Hobbies, M&M Paintworks
D-nicest is offline   Reply With Quote
Old 02-28-2008, 08:26 PM   #2754
just out of curiousity, everytime you take apart your car you have to put loc tite blue on all the screws??? what happens when you make an adjustment? for example you want more camber so you have to screw the pivot ball tighter? do you have to take it alll the way out to apply the loc tight blue? wow, what a hassle.
Joe Chaplow is offline   Reply With Quote
Old 02-28-2008, 09:17 PM   #2755
Serpent-Dan's Avatar
no you put enough loctite to fill in space on the thread in the plastic.
Serpent, Maxy's fuel, Max Power, Airtronics, Derby Bros Racing,
Kamikazercracing
Serpent-Dan is offline   Reply With Quote
Old 02-28-2008, 09:35 PM   #2756
Team Kamikaze's Avatar
Loctite are not intended for plastic, thay are only for metal to metal fasteners, so never apply loctite on plastic, it has an ingredient that actually eats up/softens the plastic.
Home of the Kamikaze Driver's Development Program
Kamikaze Toys and Hobbies Inc.
kamikazercracing.com
16749 PARKSIDE AVE. CERRITOS CA 90703
Tel.# 562-483-4422 Mon to Fri 10:00AM to 8:00PM Sat 10:00AM to 6:00PM Sun = Closed
Team Kamikaze is offline   Reply With Quote
Old 02-29-2008, 12:40 AM   #2757
Did you use the Loctite on metal-to-plastic parts as well or just metal-to-metal?
Old 02-29-2008, 12:41 AM   #2758
That's good to know. Thanks Sam.
Rob
Old 02-29-2008, 12:44 AM   #2759
I found I did not need to do that with metal-on-metal. Usually put the loctite on after a screw had been removed a few times. Someone once told me too much loctite will ruin a screw or a thread. I never had that experience. Anyone else?
Old 02-29-2008, 02:04 AM   #2760
twiggy's Avatar
i havn't had any problems with the screws backing themselves out in plastic or metal parts. The only thing i loctited on the whole car was the pivot ball retaining screws in the hubs.
www.Moorebankraceway.com
Hamilton 2008 F1 champion!
twiggy is offline   Reply With Quote
Forum Jump
FS - NEW !!!! XRAY NT18T and XRAY NT18 plus HUDY micro truck starter box w/ battery Omarko Australia For Sale/Trade 2 06-25-2008 07:47 PM
Xray T2, Brushed Motor Combo, Setup Tools, Xray Springs, Bodies etc... GroffBall R/C Items: For Sale/Trade 13 09-23-2007 07:53 PM
WTB: NIB Xray T1FK05 & Xray Teflon coated aluminum Shock Body Adam.A Australia Wanted to Buy 4 01-02-2007 02:30 PM
WTB: Xray T1FK05 & Xray Teflon coated aluminum Shock Body Adam.A R/C Items: Wanted to Buy 1 12-30-2006 02:26 PM
XRAY sedan spring kit / XRAY multi-diff / PRS 114t spur / RR 64p pinions / Stratus evostyle R/C Items: For Sale/Trade 6 12-19-2006 08:33 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
