Yokomo GT-4???
#151
Hey Ah10...are you going to Crystal Park again this comming weekend?? Let me know....I'll bring the motor to show you...it's pretty hot...maybe just my imagination but it goes berzerk mid to top end!!!!
#152
Not sure exactly what springs but be sure to pick up a set of GT4 springs. You'll need a wide selection of springs when you start fine tuning. For shockoil, believes it comes with 30WT as my GT4W did. Don't bother with it. Get some 40WT, 50WT, 60WT, and 70WT. I remember you saying you run on a small track so I don't think you'll go past 70WT.
As for diff lube, since you run on a small track (not sure how small), pick up some Yokomo Medium grease, Mugen 50,000 and 30,000. Always go thicker up front. Either 50k front and 30k rear is good for really tight track. For something a bit bigger and higher traction, go for Yok Medium grease up front (equivalent to Mugen 100,000) and 50k in rear.
Again, you will need to fine tune the car to your track. Make sure you get the correct tires that the fast guys are running. They make up for most of the handling.
#153
Ehhh? 30K in the rear? Your car swapping ends at Delta?
#154
gt4 set up
thanks dan for the info....
#155
If I run gear diffs next time, it will be Yok Medium lube up front and 50K rear along with softer springs. But I want to see how a try with front one way/solid rear axle combo goes first...
BTW, how was your Kawahara neg diff? Is it all its cracked up to be? I've been hearing other things...
#156
Kawahara neg diff???
Hey All
What is this for Front/Rear(Kawahara neg diff)??? Is there a Website that has any info???
Thinking about getting some Diffs for my GT4R...
Keep the Rubber(or Foam)on the Road!!!
Bradley J. Gotori
[email protected]
Bradley J. Gotori
[email protected]
#157
I am trying to figure out the best way to mount my reciever. It's the Futaba receiver that comes with the 3PJS (R113iP). It's not as small as most receivers, but it's a reasonable size. Anyway, here is my dilemma; the newer J type Futaba receiver/servo plugs come straight out of the receiver (not at a 90 degree angle like the older receivers), so on the GT-4R, the wires have to make a 90 degree turn right at the connector. It looks like there is only a few mm of clearance between the wiring and the ground. I am concerned about the wiring being eaten up by contacting the ground, so I thought about mounting the receiver on its side. If I do that, however, the side of the receiver is almost level with the bottom of the chassis. Again, I am concerned about the receiver case contacting the ground.
Any ideas/suggestions??
#158
bgotori- They don't make a neg diff for the GT4.
#159
Billy, got pics? Kind of hard to try to elaborate what you're trying to say...
BTW, keep an eye out for your mailbox. You should be getting those engine mounts from me by tomorrow or Friday.
I'm still waiting for my turnbuckles...
#160
You will get your turnbuckles, don't worry! I am going to package them up tonight for you. Along with some rod ends.
Let me take a picture of what I am talking about, and I will try to post it. I don't have a picture server, so hopefully you can attach pictures to the thread!
#161
Here's one.
#162
Here's another. See how I have the receiver mounted? It's sideways compared to the stock mounting position.
The chassis is sitting on my setup board, and you can see how close the receiver gets to the setup board with the chassis sitting directly on it. The receiver doesn't touch the setup board (I can slide a very thin piece of cardboard underneath it), but I wonder if it will contact the ground if the chassis bottoms out.
#163
Another side shot.
#164
One last one.
Thanks for the bandwidth!!!!!
#165
Hmm...how about bunching up the wires with small zipties and placing a line of them between the throttle servo and RX pack?
Not sure what to do but I currently run a Penguin Deck and just wrap the wires up and down the two zipties that hold the RX pack and then plug it straight to the receiver so there's less wire run and none comes in contact with the ground.
